Activity Forums VEGAS Pro Render issues – File too big
  • Render issues – File too big
    Posted by Rick Hughes on June 2, 2015 at 1:59 pm
    I’m using MSP 12 and DVD Arch studio 10
    Created my video … (PAL 19:9 with 5.1 audio)
    Total run time 1:55
    Step 1. Render audio as Dolby 5.1 (resulting file is 594,159 kB)
    Step 2 Enter run time, DVD size, audio type into ‘Marks Bit Rate Calculator‘ with 5% safety margin
    Step 3 Open Render video template MainConcept > DVD Architect PAL widescreen (no audio)
    Change to VBR 2 pass
    Set Max to 8,128kB Avg to 4,684kB and min to 2,784kB
    Step 4 Render (resulting file is 5,314,832 kB
    Step 5 Load files into DVD Architect and I get Red warning that files are a total of 6.3GB and too big.
    What is going wrong ? screen grab below:
    Stephen Mann replied 11 years, 2 months ago 4 Members · 11 Replies
  • 11 Replies
  • Mike Kujbida
    June 2, 2015 at 2:06 pm
    Interesting. Strange but interesting.
    I use Mark’s as well and when I entered your numbers, I got the following rates which are less than yours.
  • Nigel O’neill
    June 3, 2015 at 12:57 pm
    [Mike Kujbida] “I use Mark’s as well and when I entered your numbers, I got the following rates which are less than yours.”
    Rick is using Dolby 5.1 audio which is 448 kb/s which is a lot higher than 192 kb/s of Dolby 1.0 🙂
    Rick, it’s curious that the file is over 5.3 GB, and DVDA quite correctly refuses it. It should be close to 4.3 GB as per Mark’s calculator. Are you following the settings in the calculator exactly?
    Are you then using AC-3 instead of PCM audio in DVDA?
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 12 (x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Rick Hughes
    June 3, 2015 at 2:05 pm
    I have tried it with Dolby stereo ac3 and Dolby 5.1 .ac3.
    I think I ‘may’ have found the answer … running another Render to check – will report back.
  • Rick Hughes
    June 3, 2015 at 4:19 pm
    OK … I found an issue .. when I looked at Render with Media Info it was too long (time wise)
    Traced that down to fact I had a spurious marker out at 3.5 Hrs … so was rendering 3.5 nor 1.55
    So run it again first off audio is run at Dolby stereo ac3 192 Kb … gives file of 160,165Kb
    Entered in Marks Bit Rate Calculator
    Selected MainConcept DVD Architect PAL Widescreen
    Set to VBR 2 pass and entered the Calculator settings – (no audio stream)
    Settings are as shown:
    Rendered and results in Video file size 4,347,808 Kb
    Audio + Video = 4,507,973 Kb
    So we are better as no longer 6Gb … but when I try to put this into DVD Architect it again gives me an ‘oversize error File size of 4.8Gb
    So back to same issues why does DVD architect claim, this to be oversized ?
    No menus or anything else being added.
    The whole point of using DVD Calculator was to ensure it would fit with 5% safety margin.
  • Mike Kujbida
    June 3, 2015 at 4:59 pm
    I just realized why your numbers are different than mine (i.e. higher).
    Click the Settings box in the lower left corner of the calculator.
    Now click the 1 kilobit = 1024 bits option as shown below. I can’t remember what the rationale was for choosing this setting but it always works for me.
    My guess is that using the slightly lower numbers will finally worj for you.
    BTW, there are times that DVDA will say that the file size is too large even though you know that you’re under the limit. If that happens, ignore the warning and DVDA will happily prepare your DVD for you 🙂
  • Rick Hughes
    June 3, 2015 at 8:16 pm
    Mike … I’m confused.
    The only reason I set it to 1000 is because that is what you told me I should use as settings in the post of 2 weeks ago
    https://forums.creativecow.net/readpost/24/988604
    i.e.
    I make a few changes to the default settings by clicking the Settings button (lower left) on the main screen.
    Click 1 Kilobit = 1000 bits.
    why the change?
  • Mike Kujbida
    June 3, 2015 at 10:47 pm
    Rick, my apologies as that’s not what I meant to type.
    I went back through several of my old posts on here and I always recommended setting that value to 1024.
    I’ve tried searching a few Vegas forums to find out why you set it to 1024 instead of 1000 but came up empty. If I find the answer, I’ll post it here.
    I checked my settings at work and at home and both are set to 1024.
  • Rick Hughes
    June 4, 2015 at 1:05 pm
    No problem Mike … I only set it 1000 as you had advised, anybody can make a typo …. 🙂
    I’ll set it to 1024
  • Nigel O’neill
    June 7, 2015 at 12:46 pm
    [Mike Kujbida] “Click the Settings box in the lower left corner of the calculator.”
    I’ve been using this calculator for years and never even noticed this button or clicked on it. Just learned something new! Thanks
  • Mike Kujbida
    June 7, 2015 at 1:03 pm
    [Nigel O'Neill] “I’ve been using this calculator for years and never even noticed this button or clicked on it. Just learned something new! Thanks”
    My pleasure Nigel. Always glad to help users discover something new.
