Activity Forums Apple Final Cut Pro Legacy Render issues
  • Posted by Ian Silverstein on March 14, 2006 at 10:28 pm
    I am working in FCP ver. 5.0.4 in the DVC HD 1080i60 codec @ 23.98 fps; my editor is working with the same parameters. We are also both using Quad G5’s, with the exception that he has a Kona LHE card. The problem is this: simple effects, such as a dissolve or blow up – which don’t usually require rendering – have to be rendered on his system before playing. We’ve been through the entire gamut of RT settings and Render Control Preferences; we’ve tried (so I think) every setting configuration, and still the problem persists. I think his sequence preset may be different: I’m using the DVCPRO HD – 1080i60 preset in a 23.98 editing timebase; his may be a Kona setting. Could this be the issue? I would gratefully appreciate any feedback on the matter.
    Kevin Monahan replied 20 years, 6 months ago 2 Members · 1 Reply
