Activity Forums Adobe After Effects render issue
  • render issue
    Posted by Simon Chmiewliski on April 22, 2010 at 4:38 pm
    Hi there,
    i have a mac pro 2×2.26 quad-core intel xeon machine with
    32GB of 1066mhz DDR3.
    I was wondering if anyone could tell me what the recommended setting within after effects cs4 would be for the quickest render results?
    before i upgraded my ram i had 8GB of the same ram but it was 8x 1GB sticks instead of 4GB sticks.
    i thought that by simply increasing my ram i would be able to utalise more cores and process more frames at a time.
    how ever this does not seem to be the case.
    any help would be much appreciated.
    Regards,
    Simon
    Simon Chmiewliski replied 16 years, 4 months ago 33,417 Members · 3 Replies
  • Simon Chmiewliski
    April 22, 2010 at 7:37 pm
    ok thanks for the tips,
    how ever where you say “6 cores x 4GB”
    do you mean in the memory and multi processing setting i set the RAM per core value to 4GB?
    because it is only allowing me to set it to 2.09 maximum
  • Simon Chmiewliski
    April 23, 2010 at 8:40 am
    Yeh just downloaded and installed the new update and it is still not giving me the option to use more than 2.09GB per core (see attached image)
    not only that my machine does not seem to perform as well within after effects, for example.
    rendering the same comp then 8GB of ram seemed to do this with a lot less trouble
    where as now it seems to be lagging hugely.
    strange
  • Simon Chmiewliski
    April 23, 2010 at 1:52 pm
    Hey Dave,
    Just tried that and still hasn’t worked.
    this is really strange as my friend has the same version of after effects on his 65 bit vista machine and he can see up to 3GB of RAM per core.
    Maybe i need to edit the preferences file?
    i’m starting to think that it was a bit of a bad idea to order the 32GB :S
