Activity Forums Maxon Cinema 4D Render issue, a whole bunch of pictures.
  • Render issue, a whole bunch of pictures.
    Posted by Paul Hinderscheid on December 13, 2014 at 11:51 pm
    Hello, I’m a newbie to Cinema 4D. And I just spent hours rendering a video intro of mine, and when I looked to find the video. It’s just a crap ton of pictures of it. I looked at a tutorial on how to do it, and followed it step by step. And even in the tutorial I watched it came out as a bunch of pictures for him as well. So I thought that was normal. It took hours to render, so I’m really hoping I don’t have to do it all over again.
    I make YouTube videos; Mostly about gaming, keeping it diverse and safe.
    Paul Hinderscheid replied 11 years, 8 months ago 2 Members · 4 Replies
  • Emir Bojorquez
    December 14, 2014 at 3:26 am
    That is called image sequences and it is one of the best ways to export a project from a 3D application, you now need a video editor like Adobe Premiere or a compositing app like Adobe After effects to render the image sequences as a video file.
    *Also you can go inside Cinema 4D >> Window Menu>> Picture Viewer >>File >> Open. Here you can select your image sequence and after the open you can select the folder and save as animation and select a new format like Quick Time or Avi, but it could loss a little quality with this method.
    If you don’t like the image sequences, for Future renders you can always change the format inside the Render settings >> Save >> Format.
    Good Luck
    Imagination is the best tool…
  • Paul Hinderscheid
    December 14, 2014 at 7:22 am
    Thank you for very much! Would Sony Vegas work? Also, I’m not entirely sure what you mean by that. Do you mean open up all the pictures into a program such as Sony Vegas, and then render it as a video? If so, do I have to change the frame rate of the pictures? Because I already tried that and it turns out really sluggish. Thank you so much for your reply.
    Video producer on YouTube. I make things. 🙂
  • Emir Bojorquez
    December 14, 2014 at 3:54 pm
    I have very limited experience using Sony Vegas, as far as i know it can handle Image sequences. It is better if your frame rate is the same that you use in Cinema 4D to render your Image sequences.
    Good Luck
  • Paul Hinderscheid
    December 15, 2014 at 12:25 am
    It worked! I just changed the frame rate in Sony Vegas. Thank you, I really appreciate it! Let me know if there’s anything I can do to return the favor.
