Activity Forums Apple Final Cut Pro Legacy Render Issue!
  • Posted by Elaine Lake on August 21, 2011 at 10:15 pm
    Hello!
    So I made an animated video in After Effects and am having issues bringing it into and working with it in FCP.
    The AE settings I used to create and render my animation are:
    HDV 1080 / DVC PRO HD 720
    When I rendered out of AE, I used a HDV 720p 30
    I brought the clip into Final Cut so I can mix in audio & narration. What frame size should I be using in FCP? Right now the sequence settings I’m using are 720 x 480 Custom which is what I used in AE and my compressor is HDV 720 p30. Yet it looks all stretched out after I render in FCP 🙁
    Please and thank you for your help on this!!
    Elaine Lake replied 15 years ago 2 Members · 2 Replies
  • Shane Ross
    August 22, 2011 at 4:50 am
    [Elayne Lake] “HDV 1080 / DVC PRO HD 720”
    How on earth can your settings be both 1080 and 720? That makes zero sense.
    [Elayne Lake] “When I rendered out of AE, I used a HDV 720p 30”
    HDV is the WORSE choice you can make. How about ProRes? much better. Better quality, no GOP, full raster.
    [Elayne Lake] “What frame size should I be using in FCP? “
    The exact same frame size you exported out of AE as. And frame rate…and codec.
    [Elayne Lake] “Right now the sequence settings I’m using are 720 x 480 Custom which is what I used in AE and my compressor is HDV 720 p30.”
    Hmmmm…no…that’s wrong. When something is referred to as 720p…it is 1280×720…the LAST number. 1080 is 1920×1080. You are using a 480 setting…not what your footage is. You need it to be 1280×720…but first you need to render out of AE as ProREs. Actually, what version of FCP are you running? Want to make sure ProREs is an option.
    Shane
  • Elaine Lake
    August 29, 2011 at 2:33 am
    Hey Shane
    Thanks so much for your answers & help! I’m out of town and away from my workstation so I can’t double check any of the settings / questions you asked me but I will when I’m back.
    I appreciate all your help!
    I hope to finally wrap my head around the whole premise behind sequence settings!
