Activity Forums Apple Final Cut Pro Legacy render issue
  • Posted by Brad Williams on August 27, 2010 at 3:34 pm
    I have a weird Final Cut Issue. I have a video file that is captured through a Blackmagic Extreme card into Final Cut. All of a sudden when I add sequences like lower thirds and such, when I go to render, I get an annoying General Error 0 message constantly. My work flow is the same. I am using a Lacie Esata external. I am on a Quad Core Mac pro with 6 GB of ram and running Final Cut 7. Any ideas at all what is up ? I have tried trashing preferences, restarting etc…
    Jeremy Garchow replied 16 years ago 3 Members · 8 Replies
  • 8 Replies
  • John Fishback
    August 27, 2010 at 5:40 pm
    This might be a case of corrupted media. Checkout Digital Rebellion’s FCS Maintenance Pack. There’s a Corrupt Clip Finder and they have a demo version. Also, using Render Manager, you might try trashing your renders and re-rendering.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Jeremy Garchow
    August 27, 2010 at 5:41 pm
    [Brad Williams] “All of a sudden when I add sequences like lower thirds and such, “
    Where are these lower thirds from?
  • Brad Williams
    August 27, 2010 at 6:03 pm
    sorry, they are just text lower thirds
  • Jeremy Garchow
    August 27, 2010 at 6:05 pm
    [Brad Williams] “sorry, they are just text lower thirds”
    Created in FCP?
  • Brad Williams
    August 27, 2010 at 6:25 pm
    yes, sorry, created in FCP with Boris
  • Jeremy Garchow
    August 27, 2010 at 6:31 pm
    OK, if you remove the title, and put on any filter (say a desaturation filter) and render, do you get the error?
  • Brad Williams
    August 27, 2010 at 6:37 pm
    If I remove a section of the text, it still gives me the error
  • Jeremy Garchow
    August 27, 2010 at 6:38 pm
    Don’t remove a section, you need to remove all of it. DUpe the timeline if oyu have to . I am trying to nail it down to see if it’s Boris causing the error or not.
    What format, frame rate, timeline settings are you using?
