Activity › Forums › Adobe After Effects › Render is way different than what is seen inside AE.
  • Tudor “ted” jelescu
    February 23, 2011 at 8:57 am
    One thing that can generate that kind of difference is the codec you use to render. What color depth are you working on 8, 16 or 32 bit? What codec do you use? If you render with an uncompressed codec, is the difference still there?
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Chris Bryant
    February 23, 2011 at 3:46 pm
    Thanks for the response! I’m working in 32bit and rendering with Photo – JPEG at 90 quality. I did a render with a uncompressed codec and it was the same. I realized later that I had my camera set to ‘Front’ instead of ‘Active Camera’ I was in a top view earlier and I thought I had set it back, I guess that I clicked the one next to Active Camera giving me the different renders.
    Thanks for the response again!
