Activity › Forums › Adobe After Effects › Render is Ignoring Parts of the Image
  • Render is Ignoring Parts of the Image
    Posted by John Felt on June 23, 2008 at 10:09 pm
    Hi all
    I am having a problem rendering out an After Effects sequence, and am wondering if any of the helpful people on this board might know what is going.
    Basically I have a very intense sequence-HDR, text animators, 3d. When I render a still image I get the entire image. When I render the whole thing as an image sequence, however, much of the image gets lost.
    Here are two images to compare to see the problem:
    Right: https://www.flickr.com/photos/28010218@N08/2605739238/
    Wrong: https://www.flickr.com/photos/28010218@N08/2605739402/
    Originally I was rendering it out on my Macbook pro. When that didnt work, I paid someone to render it out on their big machine. They had the same problem.
    Any thoughts out there about what I could do to get it out?
    Thank you very much for any help–I am pretty desperate at this point to get it out!
    Part1c (00260)
    Bill Kelly replied 18 years, 3 months ago 3 Members · 5 Replies
  • John Felt
    June 23, 2008 at 10:58 pm
    Hi David
    Thank you for the reply. What do you mean a custom view? It’s definitely on “Active Camera” in the view choice at the bottom of the comp panel, if that’s where you’re referring too.
    Also, I am able to render out the image when I do it as just one still image. It just won’t work when I do it as an image sequence.
    Let me know if that answers your question and if you have any other thoughts. I appreciate the help immensely.
    Thanks again
    John
  • Kevin Camp
    June 24, 2008 at 12:19 pm
    maybe not all the effects that you are using are comatible with 32bpc processing and that is causing a problem…? i’m grasping here, i haven’t seen this before….
    of course the painful workaround is to render each frame manually…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • John Felt
    June 24, 2008 at 3:27 pm
    I appreciate the help, but thats not it either. Im pretty sure all the effects are 32 bpc, but either way, some of the 32 bit material gets out, so that can’t be the problem.
    Yeah, its pretty weird….too bad its also driving me nuts. Any other thoughts out there? Again I appreciate the help immensely.
  • John Felt
    June 24, 2008 at 3:43 pm
    Just to give some idea–I have tried seemingly everything and I havent been able to locate the problem. If I turn my comp to 8-bit, I still have the same problem. If I jsut export one of these text “galaxies” I have the same problem. I have played around with settings in the secret menu too.
    All this makes me believe that it does not have to do with how intense the processing of each frame must be, but something else. What that is I have no idea, but I’m hoping someone out there might.
    Thank you all again.
  • Bill Kelly
    June 25, 2008 at 1:44 am
    I don’t know if this will help, but you may want to try rendering it out as a Quicktime movie with the Animation codec. If this gives you the correct result, open up the movie with Quicktime pro and export it as an image sequence.
    I’d first try just rendering out a few frames as a Quicktime movie to see if it works (so you don’t waste your time waiting for the full render if it doesn’t).
