Activity › Forums › Maxon Cinema 4D › render is balck?
  • render is balck?
    Posted by Lars Wikstrom on October 23, 2006 at 4:15 am
    My renders are not shoing up? I had an object that was rendering fine in the view but when I render to disk of do a preview render it is black? I don’t have any composite tags and I have the always show in render turned to on. but nothing?
    -Lars
    Lars Wikstrom replied 19 years, 11 months ago 2 Members · 2 Replies
  • Mylenium
    October 23, 2006 at 5:40 am
    Check the picture viewer menu. Maybe you have incidentally turned on the Alpha channel view (which in your case woould be empty and show black) or you are using the multipass previw and also have an empty channel show up.
    Mylenium
    [Pour Myl
  • Lars Wikstrom
    October 23, 2006 at 7:58 pm
    I did check that and they were both set to view normaly. I dropped a simple cube in right next to my model and rendered. The cube showed up in the render but my object did not. I finally delete it and re imported it and it worked.
    Thanks for you insight.
    -Lars
