Activity › Forums › Adobe After Effects › render in after effects
  • render in after effects
    Posted by Gon Perdigao on June 3, 2009 at 7:08 pm
    Hi there, i notice that when i render in after effects, the render output is darker than the footage that i was working.
    The monitor is the same, and i didn’t use any color treatment.
    Is there a reason to this happen? Is there a way to solve this?
    Thanks a lot
    Todd Kopriva replied 17 years, 3 months ago 2 Members · 5 Replies
  • Todd Kopriva
    June 3, 2009 at 7:35 pm
    We need a lot more information. Exactly how are you rendering and exporting? To what format? Using what codec? What version of After Effects are you using? Et cetera.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Gon Perdigao
    June 3, 2009 at 8:33 pm
    i’m using after effects CS3, the export i’m doing in quicktime animation, photo-jpeg and png.
    I’m rendering adding to render queue.
    When i’m rendering i use full quality, or half.
    Best settings :
    Quality – Best
    Resolution – Best
    Disk cache – Read only
    No proxies are being use
    Effects – current settigs
    Solo switches – current settings
    Guide layers – all off
    Color depth – current settings
    Time sampling :
    Frame blending – on for checked layers
    Field render – off
    Motion blur – on for checked layers
    time span – work area only
    Options – use store overflow
    lossless :
    Format – Quictime movie
    Embed – Project link
    Post render action – None
    Video output :
    channels – RGB
    Depth – millions of colors
    Color – premultipled (matted)
    Spatial quality – most (100)
    This are the settings that i use, is necessary any more information?
  • Todd Kopriva
    June 3, 2009 at 8:38 pm
    Do you have the 8.0.2 update installed? It fixed some issues with QuickTime and gamma-related color shifts.
    Here’s a Technical Support knowledgebase document that should help:
    “QuickTime movies exported from After Effects CS3 are darker or lighter than expected”
  • Gon Perdigao
    June 3, 2009 at 8:46 pm
    how do i see that?
    Thanks a lot for your reply
  • Todd Kopriva
    June 3, 2009 at 8:50 pm
    You can check to see what version of the software you have installed by choosing About After Effects from the After Effects menu (Mac OS) or the Help menu (Windows).
    BTW, it really helps if you provide your operating system information when asking questions, too.
