render in 8bit or YUV?
Hi all,
can someone explain the benefits or possible drawbacks of changing the default render in 8bit setting in the sequence settings tab to render in high precision YUV.
my sequence is PAL DV50 with a mix of DV50, DV25 and AE animations rendered to Prores 422
would i gain anything by moving to YUV rendering?
thanks
Macpro Duel core 3Ghz
4.0G RAM
OS 10.4.10
QT 7.2
FCP 6.0.1
AE CS3
BMD Decklink HD Extreme 6.6
PAL Land
