Activity Forums Apple Final Cut Pro Legacy Render/ Hard Drive question
  • Render/ Hard Drive question
    Posted by Alec Beard on December 1, 2009 at 1:42 am
    I have a 4×2.5 PowerPC G5 that I use for Final Cut. I have a 1TB external hard drive for storage. I’m looking into buying an internal SATA drive for rendering. So basically I’d have
    Original system hard drive
    External for Storage
    SATA internal for Rendering.
    My question is whether I should just put the render files on the SATA? Nothing else on there? Will it be slow to use the system drive to run Final Cut but render on the SATA? I’m thinking SSD, since they seem to be the Usain Bolt of hard drives.
    Alec
    Steve Eisen replied 16 years, 9 months ago 3 Members · 2 Replies
  • Shane Ross
    December 1, 2009 at 2:09 am
    I keep my render files and media files on the same drive. There is no issue doing so…unless you are running low on storage. In which case, that is a fine solution.
    [Alec Beard] ” Will it be slow to use the system drive to run Final Cut but render on the SATA?”
    No. This is how you are supposed to do things. FCP on OS drive, media and renders on a separate drive. Normal operation.
    [Alec Beard] ” I’m thinking SSD, since they seem to be the Usain Bolt of hard drives. “
    Yeah, but kinda expensive for this really. Unless you are keeping both REnder and media files on that drive, you won’t see any speed boost.
    Shane
  • Steve Eisen
    December 1, 2009 at 2:39 am
    Alec
    If you want to add more internal drives to your system, you should check out the G5 Jive.
    https://eshop.macsales.com/search/G5+ive
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
