Activity Forums Adobe After Effects Render half resolution keeping the media quality
  • Render half resolution keeping the media quality
    Posted by Peeter Tamia on March 2, 2011 at 7:41 pm
    Hello,
    At times I like to render a video at half resolution (for quick rendering purposes) but I would like to keep the images that I use in the project at a high resolution because they are small images that I scale up anyway in the project. I don’t want the images to lose even more quality when rendering the video at a half resolution. Because the images have lost some quality already when I scaled them up, I don’t want them to degrade any more but I do like to render out the video at half resolution, but I don’t want to take away every second pixel from the images that I have imported in the project.
    I have also tried to post this topic on videocopilot forums but somewhy it is deleted without any particular reason every time I post it, leaving me clueless.
    I hope anyone can give me some hints here.
    Regards,
    Peeter
    Cassius Marques replied 15 years, 6 months ago 4 Members · 4 Replies
  • Walter Soyka
    March 2, 2011 at 7:46 pm
    [Peeter Tamia] “At times I like to render a video at half resolution (for quick rendering purposes) but I would like to keep the images that I use in the project at a high resolution because they are small images that I scale up anyway in the project.”
    You can’t have it both ways — rendering at half-resolution only considers half of the pixels.
    If you want to speed up renders for previews like this, you could render at full quality (which will preserve your images), but use low-res proxies [link] of some of your more complicated or render-heavy pre-comps.
    Walter Soyka
  • Paul Roper
    March 2, 2011 at 8:14 pm
    You could try creating a new comp in After Effects at half the size of your ‘main’ comp. (Eg. if your main comp is 1920×1080, make your new comp 960×540). Drop your ‘main’ comp into it and scale it to 50%, and switch on ‘continuously rasterize’ (the little sunshine icon) for the layer in the timeline. Then render this at full resolution (960×540) and you’ll have yourself a half-res QuickTime movie (or whatever format you choose) with the images as good as they can be.
    Probably. Without seeing the project, I can only really guess, but this is how I’d do it.
  • Cassius Marques
    March 3, 2011 at 2:10 pm
    You don’t have to collapse transformations when scalling down a composition. And that wouldn’t speed things up… the render time would be the same as rendering in full res.
  • Cassius Marques
    March 3, 2011 at 2:15 pm
    Maybe you can set everything but the images to Draft, and render full size or half size(full scalled down). I’m just not sure if the draft quality will come close to half, or w/e it’s based on.
