Activity › Forums › Maxon Cinema 4D › Render Glow dies out on angled objects
  • Render Glow dies out on angled objects
    Posted by Brian Murphy on April 28, 2009 at 5:38 pm
    Hey guys,
    I have had better luck with the GLOW setting through the render menu than I have in a material, however using both at one time or another has brought me the problem of not rendering the glow on areas of an object that seem to be angled slightly, not at a 90 degree angle or similar. For the GLOW in the render settings, how can I eliminate this? I want that glow evenly around the whole object no matter how it turns.
    Brian
    Brian Jones replied 17 years, 5 months ago 2 Members · 1 Reply
  • Brian Jones
    April 29, 2009 at 4:21 pm
    do you have Noise or Surface Normal Attenuation turned on in the settings?
