Activity Forums Avid Media Composer render from Ae for Import in Avid eXpress Pro
  • render from Ae for Import in Avid eXpress Pro
    Posted by Coverbee on August 23, 2006 at 8:14 pm
    Hi there
    I’m still not sure what to do, please advice.
    I made some textgraphic in Photoshop CS, sqare pixels and all.
    Then I imported the layers into After Effect 6.5 as a comp.I animated it and added a few effects. nothing to hot I think just a lightsweep effect, some level adjustment, some fastblur etc.
    All the composition I made in AE where square pixels.
    I rendered my final comp using animation codec, millions of clors +, rgb plus straight alpha, field rendering even lowerfield first.
    Just to check things I import the quicktime render into Avid Free DV. Importsettings : Maintain, square; RGB;
    Invert existing alpha; Even (lowerfield first.
    Somehow it looks a bit funny. wht little red dots wher is supposed to be transparency. It looks a bit like opening a QT with alpha in the quicktime player, since it is not capable of ‘showing’ an alpha channel.
    I’m not sure at what stage things go wrong….
    Is Avid Free DV capable of handeling an Alpha channel or not
    I’ll be glad to hear from you again.
    Best regards
    btw. I’m working on an Apple G5. PAL format.
    Coverbee replied 20 years, 1 month ago 2 Members · 2 Replies
  • Satesh Ramjattan
    August 24, 2006 at 12:08 am
    if you are using PAL then you have to render upper fields. Don’t know if it will fix the problem though, I have never worked in PAL.
  • Coverbee
    August 24, 2006 at 12:17 am
    you’re right
    I totally forgot
    thanks
