Activity › Forums › VEGAS Pro › render format for dvd
  • render format for dvd
    Posted by Jeff Powell on November 27, 2007 at 3:51 pm
    I have about 1.5 hours I of video I need to put on a DVD. I first tried to render as an AVI but the media was too big to put on a DVD in architect. I am using Vegas 8 and architect 4.5. I then tried to render as mpeg 2 but got no audio. So ended up w/ mpeg 1. The problem is the picture is not that clean. It looks like a compressed web video. What do I need to get that much video on a DVD?
    Mike Kujbida replied 18 years, 10 months ago 2 Members · 1 Reply
  • Mike Kujbida
    November 27, 2007 at 8:42 pm
    You can give an AVI file to DVDA and have it do the encoding for you.
    You need to render an AC-3 stream (the audio portion) as well.
    If you give it the same name as the video portion (eg. myvideo.mpg & myvideo.ac3) and put it in the same folder, DVDA will automatically load the audio once you load the video.
    Render it out as MPEG & AC-3 streams.
    For 1.5 hr. use the following bitrates as recommended by the bitrate calculator (note: this links to a zipped file) I use.
    AC-3: use the default stereo template
    MPEG-2: use the DVD Architect NTSC video stream template but customize it by clicking the Custom button and then the Video tab.
    VBR: 7,700,000 / 6,600,000 / 3,600,000
    CBR: 6,100,000
