Activity Forums Apple Final Cut Pro Legacy Render Format & Compressor ?
  • Render Format & Compressor ?
    Posted by Thomas Mcmurry on September 12, 2010 at 9:01 pm
    I have a short video I have exported full res quicktime in animation (720×540) that I have to supply to a vendor wit the specs below. How best to get this done with Compressor or QT PRO? Compressor doesn’t offer some of these formats. Any suggestions? THANKS!!!!
    Input Formats: (in order of preference): MPEG-2, Windows Media Video, FLV (On2 VP6 or Spark codecs). MPEG-4; Quick Time is not preferred (videos perform poorly in our category page player).
    Minimum Video Quality: at least 720px wide, at least 872 kbps. Either 4:3 or 16:9 aspect ratios work equally well.
    Minimum Audio Quality: 128 kbps stereo, 44100 hz sample rate
    Thomas Mcmurry replied 16 years ago 3 Members · 3 Replies
  • John Fishback
    September 12, 2010 at 9:41 pm
    When exporting it’s usually best to export a QuickTime Using Current Settings. Then use that in Compressor. In the past, animation codec was used since it had an alpha channel. It’s now a fairly old codec. ProRes would serve you better – higher quality and smaller file size. But, getting back to your deliverable, it appears they are asking for a file they can use directly on their site. I think an FLV as described would look best, but you can make an H.264 movie in Compressor at their data rate with a 16×9 size of 720×360 or 4×3 at 720×480. Then simply change the extension of the file from .mov to .flv.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Rafael Amador
    September 13, 2010 at 2:34 am
    [thomas mcmurry] “Input Formats: (in order of preference): MPEG-2, Windows Media Video, FLV (On2 VP6 or Spark codecs). MPEG-4; Quick Time is not preferred (videos perform poorly in our category page player).”
    – MPEG-2: You can do it in Compressor. Probably they want a Transport or Program Stream.
    – WMV: You need Flip4Mac in your computer.
    – FLV (On2 VP6 or Spark codecs): You need a Flash compressor. or, better, fallow John advice about H264.
    rafael
    http://www.nagavideo.com
  • Thomas Mcmurry
    September 13, 2010 at 6:50 am
    Wow. Thanks. Good tips.
    I didn’t realize I can just change “.mov” to “flv” and have it work. I’ll give it a go. Thanks
