Activity Forums VEGAS Pro render for dvd architect
  • render for dvd architect
    Posted by Jeff Powell on September 2, 2008 at 10:29 pm
    hello all. I know I have seen this before but can not find it…I have a two hour video I need to render to put on a DVD using architect. If I render now it is 3.5 gigs. architect shows it as 154%. thanks for any help
    Terry Esslinger replied 18 years ago 3 Members · 2 Replies
  • Jeremy Rasnic
    September 3, 2008 at 3:01 pm
    Just ignore it if you know you are below the limit of the disc you are using. DVDA is not the greatest at estimating the amount of space a file is going to take up.
    If you do find that your project is bigger than you thought and exceeds the disc quota, you can change the bitrate to a lower number to make it fit (but this lowers quality). If it is just a little bit over, you may want to shorten your menu but you should leave some room on the disc.
    j razz
  • Terry Esslinger
    September 3, 2008 at 4:50 pm
    You can use a bitrate calculator to see what bitrate you should be using. (Google it)
