Activity Forums VEGAS Pro Render for blue ray
  • Render for blue ray
    Posted by Harry Singh on October 7, 2016 at 6:32 pm
    Hello.
    Thank to creative cow , because there is such platform where we can sort our problems related to our profession. there are many many genius people who has a lot experience in their specific field.
    i am working in Sony Vegas pro from last 4 years but every time i have new challenge.
    before now i was working on free lancing from my home. but one week before i join one job on monthly income basis in one studio. They Are production in wedding videos ans working in Sony a7 and cannon 5D mark cameras. for videos . some time Sony nx1 also. and editing mostly they are doing in ( Grassvelly Edius 5.5 ) and they give to client Blue rays
    at this moment they hire me for one month probation period they will see my work in month after they decide they will continue or no.
    now my problem is here to come i found they render whole project in edius with Mpeg 1920×1080 25 frames with Constant Bit rate 80 Mbps. he render file is big 1 Hour is approx 40 Gb. and their file extension is .mpeg ,
    after they make blue ray with this rendered file in another software like
    but when i render project in sony vegas pro 13 with mpeg 2 1980×1080 25 frames with 80 mbps. =but the quality is not good as grassvelly edius. and my file extension is .m2t avchd video,
    2nd sony vegas pro take 5 hours for 1 hour project file. and edius take 2 hours for 1.30 hours video.
    Edius computer specs is
    i7 6700k with asus mother board. 8 gb 1600 mhz ram with nvidia gtx 960 Graphic
    Sony computer specs is
    i7 4770k with GigaByte H87 mother board. 16 gb 1600 mhz ram with amd r7 260x Graphic
    now my question is am i missing Something to render for blue ray. or what i do to render with good quality. for blue ray
    i tried one method i apply sony fx ” Levels ” whole video track ans set to ” computer rgb to studio rgb ”
    it enhance the contrast. but they catch my this trick.
    the output is more Detail and colours thn i render in sony vegas pro . here i send my medi info which i checked both pc.
    please guide me what i should to do to take full advantage on sony to alive my job
    thnx .
    this the footage of Sony A7 Cameras.
    General
    Complete name : C:\Users\King\Videos\New folder\00000.MTS
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 19.4 MiB
    Duration : 6 s 748 ms
    Overall bit rate mode : Variable
    Overall bit rate : 24.0 Mb/s
    Maximum Overall bit rate : 28.0 Mb/s
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.2
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2 frames
    Format settings, GOP : M=1, N=12
    Codec ID : 27
    Duration : 6 s 240 ms
    Bit rate mode : Variable
    Bit rate : 22.8 Mb/s
    Maximum bit rate : 26.0 Mb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 50.000 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.220
    Stream size : 17.0 MiB (87%)
    Audio
    Menu ID : 1 (0x1)
    Format : AC-3
    Format/Info : Audio Coding 3
    Mode extension : CM (complete main)
    Format settings, Endianness : Big
    Codec ID : 129
    Bit rate mode : Constant
    Bit rate : 256 kb/s
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 kHz
    Frame rate : 31.250 FPS (1536 spf)
    Compression mode : Lossy
    Stream size : 195 KiB (1%)
    Text
    Menu ID : 1 (0x1)
    Format : PGS
    Codec ID : 144
    Duration : 5 s 695 ms
    Regards
    harry
    Harry Singh replied 9 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
