Activity Forums Apple Final Cut Pro Legacy render files still missing
  • render files still missing
    Posted by George Bonilla on February 12, 2009 at 9:51 pm
    I am still having the same problem. We sent a drive to LA to transfer a fcp movie to tape. When he recieved it it is missing lots of render files. He tries to re-render and it gets half way then he gets a gereral error code and it stops. Thanks so much for the suggestions. Unfortunately it did not work. He still has render files missing and when he tries to
    re-render he gets the general error code. I did test the drive on 3 different computers before we sent and it worked and opened fine? What would you suggest? He did trash the render files then tried to re-render. He did try and re-start. I did send it with the render files. Could it be because his system is a 6.0 fcp and I did it on 5.2 fcp? I jsut don’t know/ Here is his reponse:
    Hey George,
    I tried these various “fixes” and I am still unsuccessful. Maybe you should take back the hard drive and re-render everything. Then just send us an uncompressed video file, audio track and m&e track.
    George Bonilla replied 17 years, 7 months ago 1 Member · 1 Reply
  • George Bonilla
    February 13, 2009 at 12:50 am
    Follow up. Tried deleting the render files using render manager. Here is the response I got from the tech in lA after he did it:
    unfortunately…no. I’ve went through render manager and deleted the render files. I’m getting this “general error” messages that pops up when I render on the edmMASTERsme sequence. I tried this on another mac and I get the same message. The problem seems to lie in the music and effects sequence. I tried exporting that sequence that way I could bring it into the master sequence and replace the old track, but I keep getting that error message.
    Any ideas?
