Activity Forums Compression Techniques Render files online? Problem with mov-file
  • Render files online? Problem with mov-file
    Posted by Kenneth Tolaas on May 28, 2011 at 11:52 am
    Hello. I have got a file from a Mac-user. I can view the file in VLC on my PC, but I can not take it into Vegas, Premiere++
    When I try to render it with Adobe Media endcoder, it mixes together video from maybe five seconds back and forth, so its just a mess.
    The file is 720p50.
    I was woundering if there is a site online where I can upload the file, and have them render it it into a .avi (or other format) that Vegas can accept?
    Or if you have any suggestions on downloadable programs that can render “problematic” .mov-files.
    -Kenneth
    Craig Seeman replied 15 years, 3 months ago 2 Members · 3 Replies
  • Craig Seeman
    May 28, 2011 at 1:47 pm
    Without knowing the problem there’s no way of knowing what will handle it. Try MPEGStreamclip for example. You could try ffmpeg as well which might handle it since VLC can.
  • Craig Seeman
    May 28, 2011 at 2:51 pm
    ffmpeg is a command line tool. Someone might have a GUI for it. I know there’s one on the Mac side of things. There’s an ffmpeg forum on the COW so they may explain what you need to do to compress the files to a usable codec.
    https://forums.creativecow.net/ffmpeg
    You should also download MediaInfo to determine what codec is actually in the file.
    https://mediainfo.sourceforge.net/en
  • Kenneth Tolaas
    May 28, 2011 at 2:54 pm
    I see.
    Mpeg streamclip only gives me a white image + audio.
    Ffmpeg I was finally able to download, but nothing happens when I click the .exe-file, so I dont know whats the thing there.
    But thanks anyway..
