Activity › Forums › Apple Final Cut Pro Legacy › Render files in Weird Places
  • Render files in Weird Places
    Posted by Martin Phillips on January 13, 2011 at 12:55 pm
    Have had a problem over the past couple of days with FCP7 taking quite a long time to open. Went and had a quick look in the FCP package contents and found a Render folder in the MacOS folder. Removed it and this has solved the problem immediately. The files are from many months back, but I always use an external raid for everything. This is not the first time that I’ve found render files in FCP package. Has anyone else come across this?
    Jeremy Garchow replied 15 years, 8 months ago 3 Members · 2 Replies
  • David Roth weiss
    January 13, 2011 at 1:46 pm
    I hate to say it Martin, but it’s got to be pilot error of some sort, most likely when restarting after a crash. Preferences are automatically trashed when the machine crashes, and if you don’t reset the disk drives properly in system settings renders will go to directories FCP creates on the system drive.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Jeremy Garchow
    January 13, 2011 at 2:59 pm
    This was/is an old problem that seemed to show up sometime in FCP6.
    I haven’t seen it in quite some time and never understood what caused it.
    I wrote about it way back in ought seven (2007) here on the cow.
