Activity Forums Apple Final Cut Pro Legacy Render files are gone. Is there a solution?
  • Render files are gone. Is there a solution?
    Posted by Noam Osband on January 7, 2016 at 3:58 pm
    I’m finishing my final project on FCP 7.0.3 It’s a 25 minute film with a lot of things that need rendering. All the time I render….close the project and eject the drive…and when I turn it on the next day, what I rendered is gone. I can see the render files existing in the render folder in my docs…..but I have the red line at the top of the sequence. Any thoughts?
    Roger Poole replied 10 years, 7 months ago 2 Members · 4 Replies
  • Noam Osband
    January 7, 2016 at 5:56 pm
    The render files are on the same external drive as the rest of the project. Should I not do that?
  • Roger Poole
    January 8, 2016 at 2:15 pm
    From what I think you are saying, you are closing your project then ejecting your media drive? Although it is good practice to eject external media drives prior to shutdown, doing that when you’ve closed your project but FCP is still running could prove disastrous. When you quit FCP it does all it’s internal housekeeping before it actually quits. So if it can’t find the media drives it can’t log the last used state.
    Eject your media drives only when you have finished with FCP and/or shutting down your computer.
  • Noam Osband
    January 8, 2016 at 6:20 pm
    I always shut down FCP completely before ejecting the drive. I mean, I can’t eject the drive without shutting down FCP. I save the project, close FCP, and then eject the drive. I still am having this problem though. Thoughts?
  • Roger Poole
    January 9, 2016 at 1:56 pm
    You could try trashing your FCP preferences. There’s a handy tool for doing this. Preference manager by digital rebellion.
    https://www.digitalrebellion.com/prefman/
