Activity Forums VEGAS Pro Render Failure – DVD Architect
  • Render Failure – DVD Architect
    Posted by Francisco Schmidt on March 6, 2009 at 9:38 pm
    When I drag an avi file to menu window in DVD architect 4.5 appear “render failure”. It happens with any avi file downloaded from internet. I’ll appreciate any help.
    Boris Wong replied 15 years, 2 months ago 5 Members · 6 Replies
  • Jeremy Rasnic
    March 10, 2009 at 2:36 pm
    Download gspot and it will tell you what format the avi file is in. It may be Xvid or DivX or some other unrecognized format. If you can find out what is kept in the avi wrapper, you can either A. Download the VFW codec that will allow you to use it, or B. convert it in Vegas to a format that DVDA can recognize.
    j razz
  • Francisco Schmidt
    March 12, 2009 at 3:23 am
    Ok. Thanks
  • Philip Scoggins
    August 11, 2009 at 1:27 pm
    I’m having the save problem with a project that I’ve been updating every few months for about 4 years. Several of the clips now say “Render Failure” with little no symbols in the corners of the clips.
    Nothing has changed on most of the clips, I just updated one of the commercial blocks and now over half of my clips show this.
    If I burn the DVD it only shows the text for the clip on the menu & when you select it for playback you only get audio.
    Another DVD Architect Pro 5.0 feature? And I am a legitimate user in case that changes a response.
    Philip
  • George Durakovich
    March 29, 2010 at 5:12 pm
    I’m having the same problem.
    Sometimes the problem is resolved if I delete newly – created by Sony STK – files in the video source folder or reloading the project.
    But now these schemes don’t work and I am stuck.
    I have a new computer with 4 Intel Cores and Windows 7 and just purchased the Sony package.
  • Boris Wong
    July 6, 2011 at 5:51 pm
    Did you ever resolve this issue?
  • Boris Wong
    July 13, 2011 at 2:11 pm
    Thanks for the inquiry. No, the issue is still there. As a registered user, I’ve sent a help request to Sony. To date nothing it’s nearly a week since I’ve initially sent it. Bad customer service. 🙁
