Activity Forums Adobe After Effects Render Failture
  • Render Failture
    Posted by Julio Crespo on August 25, 2006 at 10:42 pm
    I receive a render failture message same time in my proyect. I have a comp with two Invig layers, one of the layer have linear wipe trans and compound blur effect, this comp have a camera with all properties linked to other camera on other comp. this other comp have two big 3d layers with grid effect, one point light, one ambient light and the animated camera. I make a ram preview and run fine but some times receive a render error and have to reload AE
    Steve Drew replied 20 years ago 3 Members · 2 Replies
  • Roland R. kahlenberg
    August 26, 2006 at 4:36 am
    Check that you have the latest Invigorator installed. There are issues with versions between Invigorator and AE.
    HTH
    Roland Kahlenberg
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
  • Steve Drew
    August 28, 2006 at 6:01 am
    When you say ‘big 3D layers’ – how big?
    AE throws in the towel on renders that are too big for it to handle.
    Bit depth changes things too – you can render much larger layers in 8bit than you can at 32bit.
    Reduce your biggest source layer (ie in photoshop) and see if the render works then.
