Render Failing but I can’t find the issue….
I’ve been trying to export/make movie my composition I created in AE CS5.
The project contains one video clip approx 3 minutes long, with a few simple titles at the beginning and the end, plus some Magic Bullet MisFire effects, nothing full on.
Here is the log created by AE:
Adobe After Effects v10.0 (Windows 64) render log for project “intro.aep”
Rendering started on 3/02/2012 at 3:09:47 PM
3/02/2012 3:09:47 PM: Starting composition “copy”.
Render Settings: Best Settings
Quality: Best
Resolution: Full
Size: 1920 x 1088
Proxy Use: Use No Proxies
Effects: Current Settings
Disk Cache: Read Only
Color Depth: Current Settings
Frame Blending: On for Checked Layers
Field Render: Off
Pulldown: Off
Motion Blur: On for Checked Layers
Use OpenGL: Off
Solos: Current Settings
Time Span: Work Area
Start: 0:00:00:00
End: 0:03:20:14
Duration: 0:03:20:15
Frame Rate: 25.00 (comp)
Guide Layers: All Off
Skip Existing Files: OffOutput Module: Lossless
Output To: C:UsersshelleyDesktopOTM Campsite Video Shootcopy_1.avi
Format: AVI
Output Info: None
Include: Project Link
Output Audio: 48.000 kHz / 16 bit / Stereo
Channels: RGB
Depth: Millions of Colors
Color: Premultiplied
Resize: –
Crop: –
Final Size: 1920 x 1088
Profile: –
Embed Profile:Post-Render Action: None
0:00:00:00 (1): 1 Seconds
0:00:00:01 (2): 0 Seconds
0:00:00:02 (3): 1 Seconds
0:00:00:03 (4): 1 Seconds
0:00:00:04 (5): 1 Seconds
0:00:00:05 (6): 0 Seconds
0:00:00:06 (7): 1 Seconds
0:00:00:07 (8): 1 Seconds
0:00:00:08 (9): 1 Seconds
0:00:00:09 (10): 0 Seconds
0:00:00:10 (11): 1 Seconds
0:00:00:11 (12): 1 Seconds
0:00:00:12 (13): 1 Seconds
0:00:00:13 (14): 1 Seconds
0:00:00:14 (15): 0 Seconds
0:00:00:15 (16): 1 Seconds
0:00:00:16 (17): 1 Seconds
0:00:00:17 (18): 1 Seconds
0:00:00:18 (19): 1 Seconds
0:00:00:19 (20): 0 Seconds
0:00:00:20 (21): 1 Seconds
0:00:00:21 (22): 1 Seconds
0:00:00:22 (23): 1 Seconds
0:00:00:23 (24): 1 Seconds
0:00:00:24 (25): 1 Seconds
0:00:01:00 (26): 0 Seconds
0:00:01:00 (26): 1 Seconds
0:00:01:01 (27): 1 Seconds
0:00:01:02 (28): 0 Seconds
0:00:01:03 (29): 1 Seconds
0:00:01:04 (30): 1 Seconds
0:00:01:05 (31): 1 Seconds
0:00:01:06 (32): 1 Seconds
0:00:01:07 (33): 1 Seconds
0:00:01:08 (34): 1 Seconds
0:00:01:09 (35): 1 Seconds
0:00:01:10 (36): 0 Seconds
0:00:01:11 (37): 1 Seconds
0:00:01:12 (38): 1 Seconds
0:00:01:13 (39): 1 Seconds
0:00:01:14 (40): 1 Seconds
0:00:01:15 (41): 1 Seconds
3/02/2012 3:10:23 PM: Finished composition “copy”.Total Time Elapsed: 35 Seconds
Log closed on 3/02/2012 at 3:10:23 PM
It doesn’t seem to show any error messages in the log, however the Render Settings dialog box says the render fails at 0:00:01:15.
I know there’s not much information to go on here as to why it’s not working but if you need any more information then I’d be happy to supply it.
Never had this kind of problem before.
Any help is grately appreciated.
