Activity Forums Adobe After Effects Render Failed
  • Render Failed
    Posted by Glenroy James on March 27, 2009 at 4:36 pm
    Hellow I’m running After Effects on a 2 G RAM PC. I have a 4min 720×405 presentation that is going to be outputted for CDRom and Web. When trying to render output the render usually fails (without error) or i get usual the usual After Effects error 108 out of memory. I have tried purging (secret). I have tried increasing ram usage and clearing disk cache. I don’t have any other drive so I’m stuck using the same HD for overflows and cache. I tried outputting at medium quality and using half resolution. I have tried using adaptive resolution and using open GL but to no avail. Can someone recommend an output setting that I can use that will be able to give me a decent quality and not fail everytime I render?
    Chris Wright replied 17 years, 5 months ago 2 Members · 6 Replies
  • Glenroy James
    March 27, 2009 at 4:53 pm
    “That sounds like you turned off Open GL just for RAM Previews.”
    Yep I was told to use adaptive resolution for compensating on previews. Now I did have Open GL “off” most times i tried to render but i’ll double check. Most of my footage files are mp3, pngs, jpegs and SWFs (that i time-remapped). I had my purging in the secrets set to 50 frames. I tried outputting to FLV and in most cases AE crashed(using the render queue). I’m resorting to “split” up my files but its proving to be a VERY tedious task.
    I’be tried playing with the settings and In some cases i reach as far as the ending only to have the render silently fail. I’m not sure what else is there to do
  • Glenroy James
    March 27, 2009 at 5:17 pm
    Ok I tried again making sure to NOT use Open GL or have it enabled. I increased my RAM usage to 100% my disk cache to its max MB usage. I uploaded a snapshot of what my output module settings were but alas…minutes away from completion it “Failed”. But why just fail and no fail and prompt an appropriate error?
  • Glenroy James
    March 27, 2009 at 5:45 pm
  • Glenroy James
    March 27, 2009 at 7:01 pm
    I had my secrets prefs set to purge every 5 frames already but disabling the layer caching and taking of the frame’s motion blurs seemed to help
  • Glenroy James
    March 27, 2009 at 8:46 pm
    Well i have upgraded my quicktime and i set the purge frames to 1. I then used 1/2 resolution on 87 high quality and I am able to get a completed render but in some parts of the video i get a blank red screen where there should be animations. My footages are all SWFs and JPEGS
  • Chris Wright
    March 27, 2009 at 9:52 pm
    SWF’s can cause crashes if they are the source footage. There’s too many compression schemes for AE to know them all. Make them uncompressed first, then red will go away.
