Activity Forums VEGAS Pro Render / Exporting HD footage
  • Render / Exporting HD footage
    Posted by Mark Dalzell on October 26, 2008 at 1:03 am
    Hello,
    I’m new working with HD footage in Vegas Pro 8 so please excuse this newbie question. What is the best codec to render a project using HD or HDV files?
    I know Vegas has quite a few codecs but I noticed that when I rendered a 2 min. test segment as an .AVI file and a QT file (3 Mpbs Video) the images looked somewhat “stretched”.
    What is the best codec to use in Vegas for this purpose? I have used MPEG 4 to make my DVD’s in the past, but is there a better codec to use for HD footage? Also, are there any 3rd party codecs that are best suited for HD footage and the final DVD?
    The video files I’m working with are:
    1440x1080x12.29.97 fps interlaced / MPEG-2
    Thanks very much.
    Mark Dalzell
    PC Specs:
    VisionDAW 4U 8-Core Xeon Workstation
    2 Intel QUAD-Core Xeon 5365-3.0GHz, 8MB, 1333MHz Processors
    16GB 667MHz Fully Buffered Server Memory Modules (2x2GB)
    Microsoft® Windows® XP Professional x64 Edition
    WDC 250GB, Ultra ATA100, 7200 rpm, 8MG Buffer Main OS HD
    MOTU 24 I/O (main) / MOTU 2408mk3 (slave)
    2 WDC 750GB, SATA II, 7200 rpm, 16MG Buffer HD (Samples)
    Plexor PX-800A 18X Dbl. Layer DVD+/-RW Optical Drive
    Front Panel USB Acess
    Integrated FireWire (1394a) interface
    Thermaltake Toughpower 850W Power Supply
    Dual ESATA Bracket
    2 WWDC 750GB, SATA II, 7200 RPM, 16MB Buffer HD (Raid 0)
    3xUAD1 Universal Audio Cards
    EVGA NVIDIA GeForce 9600GT, 512MB,
    PCI-Express, DUAL-DVI Video Card
    Dual 25.5″ Samsung 2693HM LCD HD Monitors
    Mark Dalzell replied 17 years, 11 months ago 2 Members · 4 Replies
  • Douglas Spotted eagle
    October 26, 2008 at 1:07 am
    Before specifying a “best render-to” format, it’s helpful to know what you’ll be delivering this format to, or rather, what mechanical device are you using for playback?
    That will determine the best “render-to” format.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Mark Dalzell
    October 26, 2008 at 2:52 am
    Hello Douglas,
    Thanks for your reply. I’ll see if I can answer your questions.
    The first format I wanted to render to was both Quicktime and an .AVI file so I could post them up on my site for some people to view. When I view both of them the images looked “stretched”.
    The second format will be for exporting to make a final DVD of the short film I’m shooting. It will not be Blue Ray. Don’t have a B.R. burner yet.
    When working in Vegas Pro 8.0c the image looks perfectly normal. Wonderful resolution.
    As far as “mechanical device” for playback, I’m not sure what you mean. I have Dual Samsung 25.5 HD monitors at 1920×1280 resolution.
    Mark
    October 26, 2008 at 3:20 am
    AVI is not a format you want to be asking people to download, particularly in HD…file sizes are monstrous. I’d recommend either MP4 or WMV if you want to keep file sizes down and keep quality up.
    Use the 640 x 480 template DO NOT check the “Stretch to fit” option in the render dialog. I’d use the Apple iPod export dialog for Quicktime, or use the 3Mbps template for WMV. You might get away with 1Mbps in WMV, depending on the content.
    For SD DVD, you’ll render to MPEG 2, NTSC widescreen. Tick the “Stretch to fill” option in the render dialog box.
    You can test render both of these in the Preview in Player option in Vegas, CTRL+SHIFT+M. Just render out a small section and then it will open in QT or WMP
    VASST
  • Mark Dalzell
    October 26, 2008 at 3:24 am
    Douglas,
    Thanks for your help. I will try your suggestions tomorrow.
    Are there any 3rd party codecs used for rendering that do any better
    than what is in Vegas?
    Mark
