Activity › Forums › Apple Final Cut Pro Legacy › render & export strategies for works in progress
  • render & export strategies for works in progress
    Posted by Paul Dougherty on March 29, 2011 at 12:23 am
    I’m working remotely for a client, editing DVCPRO HD on FCP 6 and constantly sending small Quicktime screeners out (320×180) representing works in progress. Sometime I export to Compressor, but more often I want to export a fast Quicktime and compress the screener (mp4) on a 2nd Mac.
    In this export process is there a way to tell or force FCP to do draft renders akin to what I see for RT playback in the Timeline… that will be more than satisfactory for these little Qt screeners?
    With the way I’m working now I get the feeling that the system is doing fine HD renders (sometimes on static hi-rez stills & some moves on same) for what will be very small screeners. When I export a Qt to hand off to Compressor on another Mac, I’m using Export Quicktime Movie current settings (DVCPRO HD) thinking/hoping that this will be relatively fast as there is no transcoding. Bottom line both techniques (incl direct to Compressor) feel pretty slow, because I believe FCP is doing fine overkill renders. This adds up for the large number of screeners I have to make, which are often interim rough-cuts.
    What the best work flow for this… export quicktime conversion and export small movies? I haven’t clocked this but suspect it too would be slow. Again I wish I could fo draft renders on image files that are being resized or animating.
    Paul
    Paul Dougherty replied 15 years, 6 months ago 2 Members · 2 Replies
  • Zane Barker
    March 29, 2011 at 5:18 am
    You may want to look into a device called the Turbo264HD from Elgato. It is a USB device that is a hardware encoder for h.264 files. Export from FCP using current settings, then bring that file into the Turbo264HD program and then enjoy faster encodes to a h264 file.
    **Hindsight is always 1080p**
  • Paul Dougherty
    March 31, 2011 at 11:58 am
    from the FCP-L… “lower render quality,in the sequence settings, render control tab.”
    shoulda found this
