Activity Forums Apple Final Cut Pro Legacy “Render Error: Insufficient Disk Space”
  • “Render Error: Insufficient Disk Space”
    Posted by Aron Zana on November 12, 2012 at 7:13 am
    Hey,
    I’ve searched around on this forum and I’ve seen that this error message has annoyed a lot of people but I haven’t been able to find a solution to my specific problem.
    I’m working on adding a music track to a short video clip in FCP. The video is a 1902 x 1080, H.264 MP4-file with the size 8.9 MB. When I’m trying to render the clip, I get the error message “Render Error: Insufficient Disk Space”. My scratch disk is set to the computer HD (I’m using a Macbook Pro) which has 1 GB free disk space. I’ve trashed the FCP preferences and restarted but same problem.
    I’d very much appreciate some help with this. Thanks!
    Nizerachi YouTube Channel
    Steven Cohen replied 13 years, 9 months ago 4 Members · 4 Replies
  • Rafael Amador
    November 12, 2012 at 1:54 pm
    That might be one of the many glitches that can happens when you try to edit an unsupported format (H264/MP4) in FC.
    [Aron Zana] “My scratch disk is set to the computer HD..which has 1 GB free disk space. “
    1GB?
    You should be happy that you are able to open your computer and even open FC.
    Just to open the system and the applications needs a certain amount of HD free space for what is called “Virtual memory”. That’s a kind of temporal memory where applications write data, and is necessary even if applications are in ‘”stand by”. Have a look to the Activity Monitor.
    Free HD space is what you need.
    rafael
    http://www.nagavideo.com
  • Brad Elliott
    November 12, 2012 at 3:20 pm
    I would recommend keeping at at least 15-20% of your hard drive free at all times.
    Drives that are less than 50% full will almost always run better than drives that are not. Drives that have less than 10% free will almost always have problems(including but not limited to running slower) outside of there isn’t enough free space.
  • Aron Zana
    November 12, 2012 at 4:01 pm
    I cleared up some space on the HD (got about 10 GB free now) and rendering works. I appreciate the help. Thanks.
    >> Nizerachi YouTube Channel <<
  • Steven Cohen
    November 12, 2012 at 10:10 pm
    Yes 1 GB is way to low for a scratch disk.
    Also I’ve heard that it is not a good idea to render and edit to you computer HD.
    Steve.
