Activity Forums Adobe After Effects Render Engine Launch Error
  • Render Engine Launch Error
    Posted by Ben Watson on August 18, 2008 at 6:23 pm
    Here is the deal: I am setting up an XP startup script to launch render engine automatically when a pc boots.
    Here is the script:
    “C:\Program Files\Adobe\Adobe After Effects CS3\Support Files\AfterFX.exe” -wf c:\test\ -re
    I orginally tried to setup the watched-folder on a mapped drive and got:
    After Effects error: You do not have read/write permissions for this folder.
    I get the same error even when I set the watch-folder to a local drive. I do have R/W access to both, so I wonder if something else is weird here? Anyone ever done this, or am I crazy?
    It seems to me that you should easily be able to launch render engine and auto launch watch folder, since this is all that render engine will do!
    Ben Watson replied 18 years ago 1 Member · 0 Replies
  • 0 Replies
