Activity Forums Adobe After Effects render engine
  • render engine
    Posted by Deleted User on May 6, 2007 at 9:19 pm
    ok, i figured it out. i was changing the render from a psd sequence to a video and it didnt like that. i left all the render settings the same and it worked YEAH.. BUT, i dont want 2160 frames of psd files, i want a video file. does that make sense. thanks
    Mike Procunier replied 19 years, 4 months ago 3 Members · 4 Replies
  • Mike Procunier
    May 7, 2007 at 1:10 pm
    Multiple machines can’t render the same movie file at the same time. Plus, if your render is interupted or crashes, you’ll still have all of the frames up to that point. Just import your psd sequence and render it as the movie of your choice. It’ll only take a few minutes, since its basically just writing a new file.
  • Steve Roberts
    May 7, 2007 at 3:25 pm
    Yep, just import the sequence and render it as a movie. It’s pretty fast.
    On long renders, I always render to a sequence first. That way, if I’ve made a mistake over a few frames or AE crashes, I don’t have to render the whole thing, just the bad frames.
    In other words, what Mike said. 🙂
  • Deleted User
    May 8, 2007 at 6:28 pm
    that makes sense, BUT is the psd sequence high quality…… Is it like avi output quailty or do i have to change some settings. thanks
  • Mike Procunier
    May 8, 2007 at 7:29 pm
    There’s no compression on the psd sequences, so you’re good to go. I do all of my stuff as psd sequences then convert to uncompressed Blackmagic quicktimes. I believe .tga .bmp .tif & .iff are all uncompressed as well.
