Activity Forums Adobe After Effects Render ends when I switch to another application
  • Render ends when I switch to another application
    Posted by Matthieu Foulet on April 16, 2014 at 1:41 pm
    Hi there,
    I have an unexpected issue when I launch a render in AE.
    The render stops (no crash, I here the little ending melody) whenever I launch it and switch to any other application (to keep on working on something or to go procrastinating on reddit) !
    I am running the latest build of After Effects CC, with multiprocessing on, using a PNG sequence render setting, on an Full HD composition, with no 3rd party plugin used.
    Any thoughts ?
    MacPro 8Core 2.8Ghz (Early2008) //
    16GB OWC RAM //
    ATI Radeon HD5770 1Go //
    OS X.9.2
    Matthieu Foulet replied 12 years, 4 months ago 3 Members · 6 Replies
  • Matthieu Foulet
    April 16, 2014 at 11:26 pm
    Can you mail me a few thousand bucks so that I can buy a second computer ?
    THAT would be helpful.
    16GB OWC RAM //
    OS X.9.2
  • Tyler Hurst
    April 16, 2014 at 11:44 pm
    Mac OSX Mavericks has a feature called App Nap where it stops powering any application that isn’t immediately in front of it. Here’s an article about it
    https://www.tekrevue.com/tip/disable-app-nap-os-x-mavericks/
    All you need to do is click get info on the application and “prevent app nap”
  • Tero Ahlfors
    April 17, 2014 at 6:16 am
    [Matthieu Foulet] “with multiprocessing on”
    You’re probably running out of RAM when you’re using other applications when rendering. That will stop the render.
  • Matthieu Foulet
    April 17, 2014 at 8:00 am
    I didn’t know about app nap, I will look into that.
    16GB OWC RAM //
    OS X.9.2
  • Matthieu Foulet
    April 17, 2014 at 8:04 am
    That’s what I thought because the issue does not occur with multiprocessing turned off.
    I will tweak my settings to see if I can get rid of the problem.
    16GB OWC RAM //
    OS X.9.2
  • Matthieu Foulet
    April 17, 2014 at 3:03 pm
    Sure, but I can’t find a good editing app for it 😉
    16GB OWC RAM //
    OS X.9.2
