Activity Forums Adobe After Effects Render Elements – VrayLight – How to composite ?
  • Render Elements – VrayLight – How to composite ?
    Posted by Bernhard Rieder on November 15, 2008 at 5:14 pm
    Hello,
    I would like to figure out, how I can composite and break down the render element called VrayLight in After Effects ?
    Some threads explained that I should get the VrayLight Element, if I use the following idea:
    RawLight x Diffuse + RawGI x Diffuse = VrayLight
    Unfortunately, I am not sure if this is correct and how I could get it done in AE.
    Here is a snapshot I do have so far:
    CLICK FOR LARGE SNAPSHOT
    Here is my Max9 Scene file:
    https://www.bernhardrieder.com/ask/test_comping_001.max
    and here are all the render elements saved as .tif files and compressed to a zip file:
    https://www.bernhardrieder.com/ask/elements.zip
    the original RGB render is also included…
    well, I really would like to know how I can just break down the VrayLight Element first.
    thx a lot for every little help,
    bernhard
    Roland R. kahlenberg replied 17 years, 10 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    November 18, 2008 at 12:58 pm
    It’s great that you’ve put up the files. Unfortunately, my machine is tied up right now. What I’ve done previously with 3D multi-layered renders is to use AE’s Blending Modes. Give those a shot.
    Cheers
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
