Activity Forums Adobe After Effects render each layer as individual file
  • render each layer as individual file
    Posted by Hillary Knox on April 5, 2011 at 2:33 pm
    I’m trying to find a quick, reliable, & easily repeatable way to do the following. It seems pretty utilitarian & is something that would need to get done often, but I only know AE in limited & focused quantities. I’m sure if I knew how to write scripts, this would be a breeze, but I don’t…
    1. I would like to take an x minute piece of footage with multiple cuts, make a duplicate layer for each cut, trim that layer to the duration of the shot, repeat ad infinitum for each cut. I have this script called Magnum Edit Detector that *should* work just fine for this step.
    2. Once all the layers are trimmed & duplicated, I would like to be able to render each layer as its own movie, in some sort of automated fashion involving numbering based on layer number. I.e. each subsequent file would named something along the lines of Comp1_001, Comp1_002, etc.
    I know how to do all of this manually, that’s not the problem. The problem is the length of time it takes to do this mind-numbingly repetitive (& human error-prone) task: selecting the next layer, manually resetting the work area, command-M, manually entering the file name, etc.
    If anybody has any ideas about how I can automated this process, I’d love to hear them.
    Thanks.
    Ron Packard, jr. replied 10 years, 11 months ago 4 Members · 6 Replies
  • Hillary Knox
    April 5, 2011 at 3:23 pm
    I’d never try to actually edit anything in AE. I suppose I could do this in Final Cut, but it would be just as much, if not more manual work, which I’m trying to avoid – not so much trying to avoid the work, but trying to avoid the mistakes that come with humans doing repetitive mindless tasks. Doing it in After Effects, at least I have a chance of automating & human-proofing more of the process. Magnum already does half the work for me, and it’s more reliable in terms of frame-accuracy than I am. I just need to figure out a way to automate, or semi-automate the render queue & the file naming.
  • Hillary Knox
    April 5, 2011 at 4:21 pm
    Yeah I know the blade tool…if I was going to do it in FCP, that’s what I’d use. I was hoping for something more automated, but until I find it, sounds like that’s the quickest way to do it.
    I’m sure I’ve got some Finder tool somewhere that I’ll use for batch renaming, or I’ll just use Automator.
    Thanks for your help!
  • Jeff Greenberg
    April 5, 2011 at 4:34 pm
    Don’t you wish there was something like Magnum for FCP? There is. It’s called Scene Detector.
    So, use it, open up the XML in FCP, drag the timeline clips back to a bin – export that and you have your problem solved (I think.)
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Hillary Knox
    April 5, 2011 at 6:47 pm
    Ah-ha! Interesting. I’ll definitely look into it. Thanks!
  • Todd Kopriva
    April 5, 2011 at 9:23 pm
    Back to the original question:
    There’s a script linked to from here that does what you asked for, rendering and exporting each layer separately.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Ron Packard, jr.
    October 27, 2015 at 2:54 am
    hey that script worked for me, and I’m using Creative Cloud AE 2015. I had to place the script in the right folder, and then access the script from the Windows menu on my Mac on AE. It works great!!! I found it puts a few black frames in, so I made it output as TIF and that way I could easily delete the offending frames. And then use Adobe Media Encoder to wrap it up as a video file.
