Activity › Forums › DaVinci Resolve › Render DPX 10bit or 16bits
  • Render DPX 10bit or 16bits
    Posted by Robin Erard on July 20, 2011 at 10:13 am
    Hello,
    What do you thing of that ?
    For a Canon 5D Mark II -> 35mm print from HD DPX- what should be the bit depth for the render in DXP ? 10bit or 16bit
    For a Scan 10bit DPX 2k -> 35mm print from 2k DPX – what should be the bit depth for the render in DXP ? 10bit or 16bit
    For a R3D 4.5K -> 35mm print from 2k DPX – what should be the bit depth for the render in DXP ? 10bit or 16bit
    My global question is, is it usefull to render in 16bit for material which is not in 16bit ?
    best
    Robin
    réalisateur, scénariste, monteur, étalonneur
    http://www.robinerard.ch
    Robin Erard replied 15 years, 2 months ago 3 Members · 3 Replies
  • Margus Voll
    July 20, 2011 at 9:22 pm
    you will probably not get anything “more”.
    unless you add greatly in correction.
    Margus
    https://iconstudios.eu
  • Peter Chamberlain
    July 21, 2011 at 1:58 am
    Part of the answer lies in the source bit depth and part in the destination.
    10 bit log DPX files have been the industry standard for many years for film out or DCP.
    If you start with 8 bit .mov there is no point making a 16 bit render unless the next system in the workflow needs it.
    Peter
  • Robin Erard
    July 21, 2011 at 7:36 am
    Hello,
    Thank you Peter and Margus for your answer.
    All the best
    Robin
