Activity Forums Avid Media Composer render display problem
  • render display problem
    Posted by Craig Anderson on November 2, 2007 at 12:41 am
    I’m working on Avid MC v2.5.3, and seem to have hit a setting that will hide anything that needs rendering when stopped, but will show it when playing. For example, titles, keys, ets…
    I can see them if I go into Effects Editing mode, but not if I’m source/record mode.
    Anybody know off the top of their head which setting to change? If I swap user profiles, I get it back, but I’d rather not build a whole new profile from scratch if I can avoid it.
    Many thanks in advance,
    Craig
    Craig Anderson replied 18 years, 10 months ago 3 Members · 3 Replies
  • Jon Zanone
    November 2, 2007 at 9:59 am
    There is a fast menu at the bottom left corner of the timeline window. Poke around in there – for there is that which you seek.
    I think.
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Michael Hancock
    November 4, 2007 at 3:54 am
    Look under your Clip Settings and make sure Render-On-The-Fly is checked.
    Michael.
  • Craig Anderson
    November 8, 2007 at 4:55 am
    Michael,
    That was it. Thanks for pointing me in the right direction.
    Cheers!
    Craig
