Activity Forums Adobe After Effects Render crashing on the same frame…
  • Render crashing on the same frame…
    Posted by Joe Laude on May 18, 2009 at 7:30 am
    Ok, here’s one I can’t find a solution online for.
    We have an AE render that was crapping out on the same frame every single time we tried to render it. Restart AE, crash. Restart computer, crash. Different computer, crash. We’ve rendered every other frame, before and after, perfectly.
    I have disk caching on. I’ve tried the secret menu trick to purge frames before the crash. We cannot get this frame to render out, and AE gives no error message as to why. The only thing that seems to be unique about this particular frame is that maybe 3 of the layers have Gaussian blur keyframes on it. Except the rest of the sequence is constant after this keyframe, and like I said, those rendered out fine. It just won’t render this one frame.
    I have a feeling this will remain a mystery, but I’m hoping someone else might know some other tricks I haven’t tried to get this one thing to render out.
    Kirsten Lepore replied 16 years, 6 months ago 4 Members · 4 Replies
  • Kevin Camp
    May 18, 2009 at 3:20 pm
    can you preview that frame at ‘full’ and 100% (settings for the downsample and size dropdowns at the bottom of the preview window)? if so, try to render just that frame (composition>render frame>file…), then import it and edit together the three pieces. that’s probably the fastest fix…
    if you wanted to keep trying to figure this out…. you might try disabling multiprocessing and disk caching to see what effect that may have…
    also, since gaussian blur is one of those opengl accelerated effects, you haven’t set the render to use opengl for rendering have you? this is an option in the render settings. to double check, add the comp to the render queue and click the render settings. in the settings window there is a check box option to use opengl rendering. make sure that it is unchecked.
    you could also try staggering those keyframes by one frame each, just to see what effect that has…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Todd Kopriva
    May 18, 2009 at 4:32 pm
    It helps us to isolate problems if you send bug reports, including problematic projects.
    To report bugs, send a detailed bug report (including information about the version number of your software, some details about your computer, et cetera) to aebugs@adobe.com.
    (You can also use the feature-request/bug-report form.)
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Joe Laude
    May 18, 2009 at 5:36 pm
    Thanks for the advice, but what ended up working was moving those keyframes over one frame. The keyframes changed to 3 on that frame, and then were constant the rest of the sequence, so moving the keyframe to the frame before and rendering just the problem frame worked. When I have some time, I might look at the things you mentioned and see if any of it was the problem. Thanks
  • Kirsten Lepore
    March 23, 2010 at 6:18 pm
    I just encountered the same problem, except there was no apparent reason why the render would always stop at the same frame. I finally got it to render with no problems once I turned off multiprocessing (render multiple frames simultaneously). Now everything is rendering fine! 🙂
    http://www.kirstenlepore.com
    kirsten.lepore@gmail.com
    (732)673-2337
