Activity Forums Adobe After Effects Render crashes entire computer
  • Render crashes entire computer
    Posted by Lifetypo on November 16, 2007 at 1:51 am
    ive done the purge frames . all the common settting changes .. and lately my comp just shuts down when i try to render anything 10 seconds or longer very strange . only happpens with after effects .. even sometimes when ive been playn a comp a few times back to back itll shut down my comp .. i was thinking damaged ram or something i have no idea really .. maybe someone else has faced the situation?
    all my specs are well above the compatble specs .. ive also got a good nvidia video card ..
    Steve Roberts replied 18 years, 9 months ago 2 Members · 2 Replies
  • Lifetypo
    November 16, 2007 at 2:00 am
    this sucks so much because ive spent the last 3 weeks on a project that i cant render out .. easily 60 hours plus on this project . tons of rotoscoping etc.. lots and lots of work . only to not be able to render it out . ive tried rendering the video in 3 diff pieces .. for a 10 sec piece and just before its done render comp shuts down .. ive got a empty comp case next to me that i punch and hit with a hammer when my working comp is acting up.. but i dont think its gonna last to much longer after this ae project
  • Steve Roberts
    November 16, 2007 at 2:42 am
    When a computer is acting up, render to a still sequence. When it crashes, see what the last frame rendered was, and start the next render after that. Also, since each frame is its own finished still, there’s no “wrapping up” of the movie at the end, which may cause the crash. I don’t know about that “wrapping up” — I could be way off base.
    But that’s a workaround, and general good practise with a flakey computer. But as for a solution, we need to see what happens at the crash:
    – Watch your RAM usage (Task Manager or Activity Monitor) to see if it gets to 100%. That could cause a crash. Secret settings should fix that, but you might have already done that. But if it always crashes when RAM usage reaches a specific amount, then yes, you probably have bad RAM. If that’s the case, can you run lean, with no other apps going, purging every frame to try to keep RAM usage low?
    – See if it crashes at the exact same frame each time. Maybe a layer with a troublesome plugin starts there?
    – Maybe queue up multiple renders, each rendering a portion of the length of the comp as a workaround.
    – are you rendering a huge file to a FAT32 drive, which can’t take over 4GB? I don’t hink so, but I had to ask.
    Let us know …
