Activity › Forums › Maxon Cinema 4D › Render “complete” image only with multi-passes?
Posted by Torgeir Bull on July 28, 2010 at 3:16 pmHi! I was wondering if it’s possible to render out a “complete” image with just setting up different multi-passes, not using the background image?
What kind of filters and settings do I have to apply to do this?Is there a good advanced multi-pass tutorial out there? I really want to master this. 🙂
Nick Barber replied 9 years, 6 months ago 4 Members · 5 Replies -
Adam Trachtenberg
July 28, 2010 at 10:51 pmYes, you can render a complete image with just multipass. The surefire way to do it is to add the blend pass and check off all the boxes. Of course you can uncheck any that you know won’t be used.
Easiest way to see the results is if you have AE or one of the other supported compositors. With AE you just export the compositing file, open it in AE, and it will automatically create a comp for you with the layers arranged with appropriate blend modes.
Nikolay Vladimirov
January 20, 2016 at 5:27 amI tried this method but in AE I have only one “beauty” pass. How to make a advanced multipass composite that is the same with the beauty pass?
As I know there is 3 way to composite multipass:
Additive: in vray you combine – Lighting+GI+Reflection+Refraction+SSS+Selfilum+Specular (everything is in Add blend mode in Ae)
Advanced Additive is the same but with more passes you combine GI Raw, Raw reflection etc.
Subtractive – From your beauty pass you Subtract (blending mode) one of the multipass channels (reflection) and in the next layer you use Add to add it again and that way you can do tweaking only on the layer that you first subtracted and than added again.
In all of these techniques the bauty should be exactly the same as the multipass compiste. I know how to do it with v-ray but what about standard Cinema 4d multipass?
Nikolay Vladimirov
Nick Barber
February 21, 2017 at 5:43 pmFigured this issue out.
Using the additive compositing technique I was able to re-build the ‘Beauty’ pass using C4D renders only.
Multi-Passes in C4D:
Separate Lights – All/Mode(doesn’t matter)/Shaddow Correction checked
Ambient Occlusion
RGBA Image
Global Illumination
Specular
Refraction
Reflection
ShadowOrdering should look like this in while compositing in AE: (top to bottom)
RGBA – Stencil Alpha
AO – Multiply
Refraction – Add
Reflection – Add
Global Illumination – Add
Lights – Add
Shadow – Multiply
Specular – NormalIn C4D make sure in the render settings you set ‘sparate lights’ to ‘ALL’ and check ‘shadow correction.
This will render out a pass for each light separately and allow for more flexibility in post.If anyone else has other compositing techniques please feel free to add.
Cheers!
-Nick
