Activity Forums Adobe Premiere Pro Render choices
  • Render choices
    Posted by Sebastian Alvarez on November 16, 2007 at 11:20 pm
    In Final Cut Pro you can select a segment or more in the timeline and ask the program to render just that using a shortcut. Recently I started using Premiere Pro CS3 and the only option I find is to select the Work Area, which doesn’t seem as straightforward to me as just selecting a clip and hitting a key combination. Am I missing something? Is there any other choice for rendering in Premiere that doesn’t involve double clicking the current range of the timeline that you’re seeing?
    Jon Barrie replied 18 years, 10 months ago 2 Members · 1 Reply
  • Jon Barrie
    November 17, 2007 at 3:06 am
    Hi Sebastian, I use FCP all the time as a freelancer. I find it frustrating the amount of rendering I actually need to do in it. Premiere shows me things that otherwise I must render in FCP. Back to your question tho. There is no other way to render a specific area. The short cuts for in and out points to the workarea bar are (alt+[) for in and (alt+]) for out. Unless you need to see what something looks like in full res with effects you don’t need to render anywhere near as much as FCP.
