Activity › Forums › Apple Final Cut Pro Legacy › render changing textup subtitle position
  • render changing textup subtitle position
    Posted by Angela Anderson on August 26, 2012 at 4:45 pm
    Hello kind creative cowers,
    I have a strange problem. I´m working on the initial edit of a 3 screen video installation, and i just moved all of my subtitles from boris to textup after learning (too late) that i could not extract a text file for translation from boris titles (ugh).
    i had to tweak the positioning of these titles to match the position of the boris titles – we´re working on a custom sized canvas (v-position of the text and vertical position of the entire frame). Needless to say, the moment I render the titles to watch the video, they change position, moving down significantly. What´s going on here? faulty plug-in?
    any suggestions welcome!
    (ps – sorry no detailed system specs now, but we´re working in fcp 7.0.3 on an imac)
    Andreas Kiel replied 14 years, 1 month ago 3 Members · 10 Replies
  • 10 Replies
  • Miriam Lefkowitz
    August 26, 2012 at 8:27 pm
    Can you reposition the textup credits so the render moves them to the right place?
  • Andreas Kiel
    August 27, 2012 at 9:42 am
    Angela,
    Saw your post by chance.
    I tried it with a 1080×1920 project. And you’re right the titles move vertically. The crazy thing is that while rendering FCP resets the values of vertical position values randomly.
    A workaround is not to use the generators vertical offset values but the motion offsets. This will keep them in place.
    Andreas
    Spherico
    https://www.spherico.com/filmtools
  • Angela Anderson
    August 27, 2012 at 3:29 pm
    Hi Andreas,
    Great – thanks for the workaround tip! I will do this. Good that you responded because I’m about to embark on another section of the video and can now go ahead with textup – thanks! greetings from bayern!
  • Angela Anderson
    August 27, 2012 at 3:36 pm
    Ah, but now a question – is there any way to change the v position of the generator in all of the clips at the same time? or will I have to go through and do this manually?
  • Andreas Kiel
    August 27, 2012 at 3:43 pm
    You got good luck, as I just checked my mail.
    Copy one modified generator, then select all the others and then “paste attributes – motion”.
    -Andreas
    Spherico
  • Angela Anderson
    August 28, 2012 at 7:47 am
    hey andreas,
    thanks for the reply! i should have been more specific – is there any way to set the v-position in the generator back to 0 for all of my clips (motion attributes are simple this way, but settings of the generator attributes seem like they have to be changed manually).
    oh, and i just downloaded titleexchange to see how the xml conversion works – it was a beautiful moment when i saw all of the subtitles appear before my eyes as a txt file – wonderful!
  • Andreas Kiel
    August 28, 2012 at 10:50 am
    Angela,
    There are two options.
    First one:
    Use TitleExchange Pro and do an FCP XML to FCP XML conversion.
    With the free version it is limited to 50 titles. And even though TEP is a quite mighty app you may lose some of your special setting if subtitles do differ in color.
    Next one:
    Use a text editor(TextWrangler).It’s quite simple.
    Export XML.
    Open the XML in the text editor.
    Search for Step thru the found items and replace the "value".
    Import the resulting XML into FCP. This sounds like a tedious work but it's much faster compared to FCP.
    If your subs do have all the same vertical offset it's kind a snip of the fingers.
    Within the text editor copy the whole "block" and use the "Find & Replace". In the "Replace" entry change the value as described above. Then press "Replace all".
    -Andreas
    Spherico
  • Angela Anderson
    August 28, 2012 at 11:20 am
    THANK YOU!!! 🙂
  • Angela Anderson
    August 28, 2012 at 11:51 am
    You know, I just followed your instructions – which seem very logical – but when i import the xml back into fcp, while it has changed the v-offset to 0, there is now an extra line between all of the subtitles with two lines…hmm…
  • Andreas Kiel
    August 28, 2012 at 12:29 pm
    Angela,
    What version of FCP are you using?
    You can also send me an email with your phone number and we can solve that for sure within a few minutes. I’m in Germany as well.
    -Andreas
    Spherico
