Activity Forums Apple Final Cut Pro Legacy Render causes change in brightness
  • Render causes change in brightness
    Posted by Stephen Smith on June 14, 2005 at 11:08 pm
    When I add an effect such as a cross dissolve it plays great in real time. When I render it the brightness changes. (I’m watching this on a broadcast monitor) I have mastered this to a Beta tape and played it in another edit bays deck. It is showing the same results.
    My system settings are set to: RT – Safe, Video Quality – High.
    Greg Penetrante replied 21 years, 3 months ago 4 Members · 5 Replies
  • Bret Williams
    June 14, 2005 at 11:32 pm
    In your sequence settings, under video processing, make sure you’re rendering in YUV, not RGB.
  • Stephen Smith
    June 15, 2005 at 2:52 pm
    I’m already set to render in 8-bit YUV. Can it be a different setting?
  • Chris Monette
    June 15, 2005 at 6:41 pm
    I’ Ven encountered this before…Delete all the renders for the sequence using Render Manager. Quit FCP and restart your computer. Then re-render everything. That is what usually works for us.
    Good luck,
    Chris
  • Chris Monette
    Good luck,
    Chris
  • Greg Penetrante
    June 15, 2005 at 8:37 pm
    In your timeline settings, set the video processing to “White” and not “Super White”. This also got rid of the luma shift for us…
    Best,
    -Greg
