Activity › Forums › Maxon Cinema 4D › Render C4D in After Effects?
  • Render C4D in After Effects?
    Posted by Eder Gobbi on February 5, 2008 at 4:51 pm
    I have a scene, this scene have a setting.. the render of this scene with this setting have 3 hours of time..
    I need an animation for this with 180 frames.. Impossible..
    Have an another method for this? I see in anething place.. Is possible render i after effects this project?
    Thanks in advance..
    Brian Jones replied 18 years, 7 months ago 3 Members · 6 Replies
  • Adam Trachtenberg
    February 5, 2008 at 10:00 pm
    You can’t just export a Cinema scene to AE and render it, as it just comes in as 2.5D layers.
    There’s no way to advise you about lowering your rendering times without more information about the scene (resolution, poly count, transparency, reflections, GI, etc.). Can you post a frame?
    AdamT
    Cinema 4DXL8 Bodypaint
    *Remember: Tues. is national Shoe Day. Wear shoes to show your support for bimetalism and the designated hitter rule!*
  • Eder Gobbi
    February 6, 2008 at 12:37 am
    Post a frame? how i make this?
    I can send for you my scene.. If you have interest in see this..
  • Brian Jones
    February 6, 2008 at 1:24 am
    the scene would be helpful, there are too many ways to make it slow to know what is causing the slowness without knowing how the scene is made.
  • Eder Gobbi
    February 6, 2008 at 1:34 am
    How i send my scene?
  • Eder Gobbi
    February 6, 2008 at 1:54 pm
    Hi..
    My scene are posted in
    https://ibbogstudio.com/jobs/arq/Cena_Piscina.rar
    If you desire see this and sned us an idea.. 😉
    This scene goes for an architect professional, and this goes for construction.. Please.. don’t use for another job.. Thanks in advance…
    Eder
  • Brian Jones
    February 6, 2008 at 8:22 pm
    well, speed of the machine is important. I’ve been rendering 004_Blur.c4d with my Mac quad 2.66 and getting 40 minutes per render (1280×1024). With GI, AO and Caustics turned on it can’t be fast no matter what.
    Caustics taken out doesn’t help speed much (a minute or two), AO removed doesn’t help much either and they both add to the image so leave them.
    The GI is always expensive in terms of time so that’s got to be the place to tweak. I would increase the GI – Max Resolution unless you just can”t and then make sure your transparent textures (the glass and water etc.) have Generate GI, Receive GI and possible Receive Caustics turned off since GI usually isn’t noticeably different with GI on or off. There are notes on things to tweak for time improvement in the Help. Check out “Speeding Up GI”
