Activity › Forums › VEGAS Pro › render = blue screen of death
  • render = blue screen of death
    Posted by Andy Gunn on August 2, 2010 at 6:30 pm
    I’ve just been trying to render a couple of projects with this program (the 9.0c – 896 build) but lately it always crashes, to the blue screen..
    I tried the https://www.ntcore.com/exsuite.php to allow vegas.exe to use more than 2G which apparently helped other users with rendering crashes, but it made no difference to my problem.
    I have a very good spec pc and it used to work fine.. so I’m a bit confused as to why it’s doing this.
    Any help appreciated.
    Andy
    John Rofrano replied 16 years ago 6 Members · 17 Replies
  • 17 Replies
  • Stephen Mann
    August 3, 2010 at 1:48 am
    You don’t list anything about your system on your profile, but..
    A BSOD is Windows way of of saying “WTF?”.
    Vegas isn’t crashing, Windows is.
    Windows will crash with a BSOD when it tries to address bad RAM, or tries to write data into a ROM address space. BSOD is actually quite rare now because Windows can usually isolate any error and close the program that was running when Windows crashed and present the equally frustrating “Windows has Encountered a Problem”.
    But at least Windows keeps running. You should note, Windows protects itself above any running application.
    So, without knowing anything about your PC and what you’re trying to edit, no one can help you here.
    I am interested in this thread, though, because I haven’t seen a BSOD in at least two or three years.
    Steve Mann
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Norman Willis
    August 3, 2010 at 5:23 pm
    Hi Andy.
    What is your OS?
    Norman Willis
    http://www.nazareneisrael.org
  • John Rofrano
    August 3, 2010 at 8:53 pm
    If you kept a backup copy of Vegas I would restore it. Otherwise I would completely uninstall and re-install Vegas Pro and not mess with anything you shouldn’t be messing with.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Andy Gunn
    August 4, 2010 at 8:44 pm
    it’s doing it with the older and newer versions..
    My pc is running XP Pro version 2002, SP3, and is a Intel Core Quad CPU, 2.83GHZ it says 2.5G ram but I’m sure it’s 4G.. so that should be a good enough spec surely?
    I mostly use the computer for audio recording. It has a RME HDSP9652 soundcard and a UAD quad card too.. but that wouldn’t throw it would it?
    Also, I just gave it the windows update..
    I’ve just tried rendering some old footage and it seems to work there, but on certain newer projects it just jumps to the blue screen..
    strange..
  • John Rofrano
    August 4, 2010 at 9:18 pm
    What does the blue screen say? There will be an error on the top and usually a filename on the bottom of the driver that caused the error. You need to look these up and see what the error means. Then get an updated driver for the driver that is causing the problem.
    ~jr
  • Al Bergstein
    August 4, 2010 at 11:14 pm
    Also,did anything change in the hardware configuration lately? These days, BSOD often are indicative of a hardware driver or component failure. Did you add/remove hardware lately? Upgrade drivers???
    What’s your format that you are rendering? HD? SD? which manufacturer, like HD AVCHD,HD AVCHD lite, HD MOV, etc…. Some odd stuff is manufacturer specific, it seems.
    Alf
  • Andy Gunn
    August 5, 2010 at 11:11 pm
    hi,
    I haven’t checked the blue screen bit yet, does it damage the computer when it does that?
    Anyway, the error box on reboot says
    Server=watson.microsoft.com
    UI LCID=1033
    Flags=1696080
    Brand=WINDOWS
    TitleName=Microsoft Windows
    DigPidRegPath=HKLM\Software\Microsoft\Windows NT\CurrentVersion\DigitalProductId
    ErrorText=A log of this error has been created.
    HeaderText=The system has recovered from a serious error.
    Stage2URL=
    Stage2URL=/dw/bluetwo.asp?BCCode=1000008e&BCP1=C0000005&BCP2=E0C06C21&BCP3=EBDE1A3C&BCP4=00000000&OSVer=5_1_2600&SP=3_0&Product=256_1
    DataFiles=C:\DOCUME~1\studio\LOCALS~1\Temp\WERc5eb.dir00\Mini010610-01.dmp|C:\DOCUME~1\studio\LOCALS~1\Temp\WERc5eb.dir00\sysdata.xml
    ErrorSubPath=blue
    DirectoryDelete=C:\DOCUME~1\studio\LOCALS~1\Temp\WERc5eb.dir00
    but I have no idea what this means..
    I haven’t changed any of the hardware recently and it seems weird that it only does it on certain projects.. the ones I really want to keep hmnf.
    I’ll look into updating the bios, but I’m not sure how to do that..
    cheers
    andy
  • Andy Gunn
    August 6, 2010 at 1:32 am
    ok, so I just tried updating everything and I think I updated the bios? I hit the little program with the ROM file beside it..? I wish I knew how to work these things.
    Anyway, it didn’t work, as I’ve just got more blue screen.
    the message says-
    *** STOP: 0X0000008E (0XC0000005, 0XE0C06C31, 0XEBE60A3C, 0X00000000)
    *** aec.sys – Address EBE60A3C base at EBE60A3C, DateStamp 00000000
    Beginning dump of physical memory
    contact syst admin or tech support or santa for further assistance.
    whatever the hell that means…?
  • Andy Gunn
    August 6, 2010 at 1:34 am
    the message says-
  • John Rofrano
    August 6, 2010 at 1:57 am
    Excellent! So your next task is to Google for “STOP: 0X0000008E” and read what Microsoft and others have to say about what causes this. There are a lot of cause including malware and rootkits. You need to see which one might apply to your circumstances.
    Then you need to Google “aec.sys” to find out what file it is. You will find that it’s a Windows system file so perhaps there is a system update from Microsoft that will fix this?
    I would start scanning your computer for malware, tojans, rootkits, etc with programs like AddAware, SpyBot, and MalWareBytes, just to rule those out as a possibility.
    ~jr
