Activity Forums VEGAS Pro Render As Question
  • Render As Question
    Posted by Thomas Frantz on January 20, 2015 at 9:52 pm
    I want to export an edited file and save it to a SDHC. Put the card into either a Panasonic HRM10 or an AC-160 camera, then play the file from one of those devices. Essentially I’m trying to roll in edited files from one of those devices from the field but after it’s been edited in Vegas. Panasonic says it uses MPEG-4 AVC H264 for recording. I know I need to match resolution/frame rate. No matter what file type I select in Vegas 11 to use to render, I can’t get the file to show up in the Panasonic devices. Any ideas? Thanks in advance.
    Image Maestro
    Thomas Frantz replied 11 years, 7 months ago 5 Members · 8 Replies
  • 8 Replies
  • Sonic 67
    January 21, 2015 at 12:15 am
    Use MediaInfo to see exactly the details of the video files that you are dealing with.
    https://mediaarea.net/en/MediaInfo
  • Norman Black
    January 21, 2015 at 3:59 am
    Have you tried Sony AVC with one of the AVCHD templates?
    The specs for those devices say they use the AVCHD format.
    Beyond those guesses I would need information about what you need. Like a MediaInfo report of a file the devices can use.
  • Danny Hays
    January 21, 2015 at 5:38 am
    I have two Panasonic avchd cameras. they use .mts files. have you tried that format? I never really use my cameras for playback.
  • Russ Froze
    January 21, 2015 at 7:58 am
    It’s not as simple as finding the right codec, the real trick is to convince the camera that the file is there. I have tried this with my Panasonic AVCHD recorders without success. Just stuffing a file in the right folder does not seem enough. I believe there is a catalog or database involved in the mix so that the camera can generate and associate preview thumbnails.
    Russ Froze
  • Thomas Frantz
    January 21, 2015 at 7:01 pm
    I think Russ is on to something with his comment that just putting the video into the right folder isn’t enough. I wonder if there’s a way to trick the index/database??
    Regardless, here’s what MediaInfo pulled from one of the SD cards that has only video recorded from the AC 160. I could swear we’ve tried settings similar to these, but could try again.
    General
    ID/String : 1 (0x1)
    CompleteName : G:PRIVATEAVCHDBDMVSTREAM�0000.MTS
    CompleteName_Last : G:PRIVATEAVCHDBDMVSTREAM�0064.MTS
    Format : BDAV
    Format/Info : Blu-ray Video
    FileSize/String : 11.5 GiB
    Duration/String : 1mn 5s
    OverallBitRate_Mode/String : VBR
    OverallBitRate/String : 1499 Mbps
    OverallBitRate_Maximum/String : 24.0 Mbps
    Video
    ID/String : 4113 (0x1011)
    MenuID/String : 1 (0x1)
    Format : AVC
    Format/Info : Advanced Video Codec
    Format_Profile : High@L4.0
    Format_Settings_CABAC/String : Yes
    Format_Settings_RefFrames/String : 4 frame2
    Format_Settings_GOP : M=4, N=28
    CodecID : 27
    BitRate/String : 1440 Mbps
    BitRate_Maximum/String : 20.9 Mbps
    Width/String : 1280 pixel3
    Height/String : 720 pixel3
    DisplayAspectRatio/String : 16:9
    FrameRate/String : 59.940 fps3
    ColorSpace : YUV
    ChromaSubsampling : 4:2:0
    BitDepth/String : 8 bit3
    ScanType/String : Progressive
    Bits-(Pixel*Frame) : 26.061
    StreamSize/String : 11.0 GiB (95%)
    Audio
    ID/String : 4352 (0x1100)
    Format : AC-3
    Format/Info : Audio Coding 3
    Format_Settings_ModeExtension : CM (complete main)
    Format_Settings_Endianness : Big
    CodecID : 129
    BitRate_Mode/String : CBR
    BitRate/String : 384 Kbps
    Channel(s)/String : 2 channel2
    ChannelPositions : Front: L R
    SamplingRate/String : 48.0 KHz
    BitDepth/String : 16 bit3
    Compression_Mode/String : Lossy
    Video_Delay/String : -50ms
    StreamSize/String : 3.00 MiB (0%)
    Image Maestro
  • Norman Black
    January 22, 2015 at 2:45 am
    The Sony AVC encoder using one of the AVCHD templates to use/edit looks like what you need. The file will be output with an m2ts extension and you may need to change the extension to mts.
    Of that does not deal with any index info the camera may have setup as has been discussed.
  • Russ Froze
    January 22, 2015 at 6:55 am
    [Thomas Frantz] “I wonder if there’s a way to trick the index/database??”
    I’m not near my Panasonic Cameras at present but if I recall correctly there are three folders and the streams are in the private folder. There must be some code that will concatenate recordings that exceed 4 gig streams and stitch them together into a single file when imported via the software provided by Panasonic. When a foreign file is inserted and this code / software does not include the foreign file name, without a reference as to include the imported file, the camera will ignore the imported file.
    That’s as far as I’ve taken my experimentation.
    Russ Froze
  • Thomas Frantz
    January 22, 2015 at 10:20 pm
    So after doing some digging and experimentation, my assistant figured it out. It turns out that there is a subtle reference to this in the tech manual and if you drill into it you learn that this is indeed a metadata issue. Without intact and properly formatted metadata, the recorder/camera won’t recognize the files copied onto the card.
    Fortunately Panasonic provides a utility called “AVCCAM Restorer” and instructions on a CD with the HMR10. After he rendered our edited Vegas file using the right file format and ran the utility, he could get a file edited in Vegas to play from the HRM10 and the AC-160.
    Thanks a lot for all the assistance. It was the group think that helped us zero in on the solution.
    Image Maestro
