Render As question
Posted by Rick Hughes on February 23, 2015 at 9:18 pmHave a large quantity of source material .. that is 720 x 576 25p (SVHS video)
Once editing finished … what is the most suitable format for “Render as” …….. this is to be burnt onto DVD for playing on Wide Screen TV’sI have used Main Concept ‘=’ match project … ‘DVD Program Stream PAL’
This is going to play (assumed) in 4:3 on a wide screen TV
I have tried a few wide screen templates but these end up with black bars either side.Is there a recommended way of dealing with this ?
Rick Hughes replied 11 years, 6 months ago 3 Members · 6 Replies -
John Rofrano
March 1, 2015 at 12:27 amYou want to use the DVD Architect Widescreen template for PAL under MainConcept MPEG2. Then render the audio as Dolby Digital AC3 and give both files the same name (just different extensions). These will feed into DVD Architect to create PAL DVD’s.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Rick Hughes
March 1, 2015 at 10:54 amThanks John …. will use those templates.
I just checked and it puts the “=” alongside the “DVD Architect PAl video stream”, I will instead swap to use the one you advise “DVD Architect PAl Widescreen video stream”
Do I set ‘output type” to be DVD or mpeg2 ?
One thing I am still unclear of under the options, is the Video bit rate.
I use VBR 2-pass ( and although not an option here normally tick to use my CUDA card)For this template it defaults to
Max bps 9,5000,000
Avg bps 6,000,000Is there a guide somewhere that lists the bps setting for optimum quality for given output format ?
If anyone has a link to point me to rather than have to explain something that perhaps should be obvious to me feel free 🙂
On the Dolby Digital AC-3 (*.ac3) … there are 2 options:
Stereo DVD
Stereo DVD, AGC onAny guide as to when AGC would or should be used ?
Nick Mcmahon
March 2, 2015 at 10:39 amRick…. this gives you a pretty good explanation of Bit Rate and ‘Videomaker’ has a whole series on youtube of stuff like this.
https://www.youtube.com/watch?v=QOn-9anLFxA&index=1&list=FL-HWq-BMThEshZxrMLtfoOw
Nick… BASE1268
3…2…1…C ya
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
John Rofrano
March 2, 2015 at 11:03 pmWhile the theoretcal maximum bitrate for DVD is 9.8Mbps, I would stay well below that if you are distributing to clients. If you find that the DVD is skipping on some players, it may be because the bit rate is too high. Just because all DVD Players should support 9.8 Mbps it doesn’t mean they all do.
The average bitrate determines the file size. 6 Mbps is considered normal. You can lower it to get more on a disk but quality will suffer. You can certainly raise it if you have enough disc space for the length of your video. In fact, you can use CBR 8 Mbps if your video will fit. I think you’re on the right path with using 2-Pass and VBR.
I’ve never used the AC3 templates with AGC. I guess you would use it if your audio was all over the place and you wanted to get it under control but this is best taken care of in your editor.
~jr
