Activity › Forums › VEGAS Pro › render as function in ms 9 platinum
  • render as function in ms 9 platinum
    Posted by Ed Vandenderen on November 27, 2010 at 11:08 pm
    Guys
    I am still at a loss as to how to utilize the “render as” function in mov stu 9 plat to end up with a blu-ray compliant file that I can then burn using imgburn say.
    I know the wizard will do this just fine but so should “render as”, seems to me.
    Where am I going wrong?
    John Rofrano replied 15 years, 10 months ago 2 Members · 3 Replies
  • John Rofrano
    November 28, 2010 at 12:25 am
    Select MainConcept MPEG2 and any one of the templates that start with the word “Blu-ray…”. If you don’t see any, then upgrade to MovieStudio HD 10. (I’m not sure if 9 had Blu-ray templates or not)
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Ed Vandenderen
    December 1, 2010 at 8:31 pm
    Hi John
    Yes, 9 has also has this.
    My problem is getting from it a file that I can burn with img burn to blu ray disc.
    What file extension am I looking for from the render that will burn, .iso, vf, vob ???
    tx
    Ed
  • John Rofrano
    December 1, 2010 at 11:59 pm
    [ed vandenderen] “What file extension am I looking for from the render that will burn, .iso, vf, vob ???”
    OK now I understand your original question. You cannot create a Blu-ray disc image from the Render menu. You can only render a file that you can use in a Blu-ray Authoring program like DVD Architect to create a disc image. I don’t know if the version of DVD Architect Studio that comes with Movie Studio 9 will make a Blu-ray disc.
    In Vegas Movie Studio HD Platinum 10.0 you can use Tools | Burn Disc | Blu-ray Disc to make a Blu-ray disc image. If you don’t have this option in Movie Studio 9 then you just found a good reason to upgrade to version 10. 😉
    ~jr
