Activity Forums VEGAS Pro “Render As” (details inside)
  • “Render As” (details inside)
    Posted by Mykmills on June 20, 2006 at 2:10 am
    Hi. I have Sony Vegas 6 and cannot, for the life in me, properly chop up a video file.
    Lets say I have a 10 minute clip that needs to be trimmed to 7 minutes. In Vegas, I highlight the 3 minutes I don
    James_j replied 20 years, 3 months ago 3 Members · 2 Replies
  • Gary Kleiner
    June 20, 2006 at 3:14 am
    The important thing is what the settings are that you use for the render.
    For example, to match what you already are working with, set the following in the render dialog:
    Save as type: avi
    Template: Default (uncompressed)
    Then in Custom tab: Video: Frame Size 320 x 240
    FYI, the preferred method is to capture video in DV avi which is much more compressed, but may look evn better than what you are getting at the reduced frame size. You need a device (box or camcorder) that will transcode the analog signal to digital, though. DV avi is 13 Gigs/hour.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • James_j
    June 26, 2006 at 2:58 pm
    To expand on Gary’s answer:
    I wouldn’t settle for a capture at that low a resolution (320X240). If you intend to make a DVD (720X480) out of it, it’s going to look terrible.
    If you can’t find a setting somewhere in your ‘TV input device’ to get 640X480, you’re going to have to consider a different method. Like he said, if you have to, borrow a miniDV camera and use that to convert – at least it’ll get your capture to 720X480.
    PS I know nothing about 8mm analog video, but I just can’t imagine it was ever limited to a resolution that low.
