Activity › Forums › Adobe Premiere Pro › Render and replace not available???
  • Render and replace not available???
    Posted by Brad Baker on March 5, 2015 at 3:41 pm
    “Render and Replace” is not available anymore for my dynamically linked After Effects comps. When I right click on the comp in my Premiere timeline, “Render and Replace” is greyed out.
    Any ideas? It was working just fine a few days ago.
    Brad Baker replied 11 years, 6 months ago 2 Members · 3 Replies
  • Sam Lanes
    March 6, 2015 at 9:22 am
    Has there been any changes to the After Effects project to which they are dynamically linked? Moved to another location or renamed in some way?
  • Brad Baker
    March 6, 2015 at 7:41 pm
    I figured it out – my preview files were set to ProRes 1920×1080 and my sequence is set up as 971×551 (odd size I know). Once I changed the preview files to I-Frame Only MPEG 971×551 everything was back to normal.
    Carry on 🙂
  • Brad Baker
    March 9, 2015 at 7:28 pm
    I thought I had this sorted out but I started a new project today and I’m running into the same issues.
    I’m unable to “Render and Replace” some of my After Effects comps in my Premiere timeline. Some work fine, others have the option greyed out. Changing the preview file format hasn’t worked in this case. And I can’t seem to find any discernible differences between the working comps and the non-working comps.
    Anyone else seen this with their projects?
